10-20-2011 02:01 AM
Does anybody have any experience with mgcbackup script.
As I understand PGW software will be running while backup is performed.
Does it have impact on call processing?
Also should the script run as mgcusr or root?
thanks
10-21-2011 05:57 AM
The script must run as mgcusr and does not impact the call processing but increase the cpu usage. It would be better run the script during minor load hours.
Regards.
10-21-2011 06:47 AM
thanks for the response.
12-13-2011 05:35 AM
Hey Kbelian,
Following is Cisco PGW2200Â backup procedure
First switch to mgcusr as PGW related task only can perform mgcusr
su – mgcusr
run this utility
mgcbackup
it will show you menu with certain options
if you want to schedule a weekly backup then follow these steps
Backup Main Menu
Note: to exit the script at anytime use ctrl-c
1. Backup Now
2. Backup Schedule
3. Backup History
4. Exit
Selection: 2
Backup Schedule Menu
1. Add a scheduled backup
2. Delete a scheduled backup
3. Delete all scheduled backups
4. List scheduled backups
5. Return to Main Menu
6. Exit
Selection: 1
Add a Scheduled Backup
Enter the name of the backup: weekly
Enter the directory to place the backup file (default=/dev/rmt/0): /opt
Enter the number of retries (default=0): 2
Enter the time between retries (default=30 seconds):
Enter the day of the week (default=everyday): wednesday
Enter the time (HH:MM): 06:00
Save this scheduled backup (y/n)? y
if you want to backup now
select option 1 from main menu
Backup Main Menu
1. Backup Now
2. Backup Schedule
3. Backup History
4. Exit
Selection: 1
Backup Now
Enter the time between retries (default=30 seconds): 30
Start the backup (y/n)? y
it will take two to three minutes to complete this process
Its better you do this during low traffic times just to be on the safe side.
