the 7900 series uses g711 and g729 while the 12sp +uses g711 and g723
If it is possible set all callmanagers to use g711 in all locations, then they will work.
otherwise depending on which routers you have, you can setup dspfarms on the routers to do the transcoding.
Richard.
