06-10-2005 05:58 AM
I tried to make a call from PSTN to 5300, but the call always was rejected. The following is the information of debug ISDN q931, please help me to find our where is the problem, many thanks!
Jun 10 20:19:10.586 : ISDN Se1:15 Q931: RX <- SETUP pd = 8 callref = 0x0087
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x0083, '8261987'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '3009'
Jun 10 20:19:10.598 : ISDN Se1:15 **ERROR**: accept_incoming_csm_call: modem problem Requested circuit/channel not
available(0x2C): b channel 0, call id 0x87
Jun 10 20:19:10.602 : ISDN Se1:15 Q931: TX -> CALL_PROC pd = 8 callref =0x8087
Channel ID i = 0xA18381
Preferred, Channel 1
Jun 10 20:19:10.602 : ISDN Se1:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8087
Cause i = 0x80AC - Requested circuit/channel not available
Jun 10 20:19:10.622 : ISDN Se1:15 Q931: RX <- RELEASE pd = 8 callref = 0x0087
Cause i = 0x8295 - Call rejected
Jun 10 20:19:10.626 : ISDN Se1:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8087
06-10-2005 08:56 AM
can you please send the output of the following commands:
sh vfc 1 v v
sh isdn st
06-10-2005 09:57 AM
Many thanks! Please find the information below:
SG-3>sh vfc 1 v v
Voice Feature Card in Slot 1:
VCWare Version : 11.32
ROM Monitor Version: 1.3
DSPWare Version : 4.1.32
Technology : C549
VCWare/DSPWare version compatibility OK
SG-3>sh isdn st
Global ISDN Switchtype = primary-net5
ISDN Serial0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 0
ISDN Serial1:15 interface
dsl 1, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
Layer 3 Status:
Active dsl 1 CCBs = 0
ISDN Serial2:15 interface
dsl 2, interface ISDN Switchtype = primary-net5
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
Active dsl 2 CCBs = 0
The Free Channel Mask: 0x00000000
ISDN Serial3:15 interface
dsl 3, interface ISDN Switchtype = primary-net5
Layer 1 Status:
DEACTIVATED
Layer 2 Status:
Layer 3 Status:
Active dsl 3 CCBs = 0
Total Allocated ISDN CCBs = 0
06-10-2005 10:37 AM
the DSP and the D-channels seem to be up and ok. can you please send me the dial-peer configuration?
06-10-2005 10:45 AM
I'm new to this. How can I get the infomation?
06-10-2005 11:27 AM
first try to explain me exactly what you want to do. when the call comes from the PSTN where do you want to send it?
the dial-peer section is located in the buttom of the show run output.
06-10-2005 11:54 AM
When 5300 received a call, it will accept the call and reponse with a voice welcome message, just like what every call card service providers do. But when I made the call, it was rejected by 5300.
I run the sh run command, it returns a long text about the dial-peer, so I can only paste part of it:
dial-peer voice 88991673 voip
preference 3
destination-pattern 673T
session target ipv4:215.10.100.*
tech-prefix 3267
dial-peer voice 88991855 voip
preference 3
destination-pattern 855T
tech-prefix 3267
dial-peer voice 889911 voip
preference 3
destination-pattern 1T
tech-prefix 3267
dial-peer voice 8899145 voip
preference 3
destination-pattern 45T
tech-prefix 3267
06-10-2005 01:28 PM
you are missing the codec configuration on the VOIP dial-peers and i don't know if it was in purpose or not, but the last ocetc of the IP should be the host (not *).
please attach the debug output of "debug voice ccapi in".
06-12-2005 03:35 AM
debug voice ccapi in:
Jun 12 19:41:12.116 : //-1/xxxxxxxxxxxx/CCAPI/cc_handle_periodic_timer: Ca
lling the callback, ccTimerctx - 0x625500C0
Jun 12 19:41:12.116 : //-1/xxxxxxxxxxxx/CCAPI/ccTimerStart: ccTimerctx - 0
x625500C0
