Need Help with ATA 186
brandoncheah
Hi all,
I need help with a Cisco ATA 186. Our company has installed a analog intercom and since we are running a VOIP network, i had to hook the analog inetrcom through a ATA 186 and patched the ATA 186 into our network. Everything is working fine, however when you press the off hook button on the intercom, you only get a dial tone.
My question is: is there any way of telling call manager or the ATA to dial an extension immediately when the intercom goes off hook, instead of getting a dial tone? There is no key pad on the intercom so the user has no way of inputting any extensions.
What i would like to accomplish is to just assing a shared line on multiple phones so that when a user presses the intercom line, it automatically dials the shared line i have programmed into the phones.
Please help!! Thank you.
Brandon Buffin
You can configure PLAR for the ATA186 port. Take a look at the following link.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080232b9f.shtml
Hope this helps. If so, please rate the post.
Brandon
5 Replies 5
Brandon Buffin
Brandon
Brandon,
nice name btw :) I followed the instructions to the tee and it worked, it took a little configuring but it works as advertised. Thank you for your response and the link.
Link isnt working.
Brandon,
You can simply remove /partner from the link and it should work. Try this one:
http://www.cisco.com/en/US/docs/voice_ip_comm/cata/186_188/2_15/english/administration/guide/sip/SIP88APE.html#wp1047217
Hope this helps.
Brandon
