Hi all,
I need help with a Cisco ATA 186. Our company has installed a analog intercom and since we are running a VOIP network, i had to hook the analog inetrcom through a ATA 186 and patched the ATA 186 into our network. Everything is working fine, however when you press the off hook button on the intercom, you only get a dial tone.
My question is: is there any way of telling call manager or the ATA to dial an extension immediately when the intercom goes off hook, instead of getting a dial tone? There is no key pad on the intercom so the user has no way of inputting any extensions.
What i would like to accomplish is to just assing a shared line on multiple phones so that when a user presses the intercom line, it automatically dials the shared line i have programmed into the phones.
Please help!! Thank you.
Solved! Go to Solution.
You can configure PLAR for the ATA186 port. Take a look at the following link.
Hope this helps. If so, please rate the post.
Brandon
Brandon
Brandon,
nice name btw :) I followed the instructions to the tee and it worked, it took a little configuring but it works as advertised. Thank you for your response and the link.
Hotline (PLAR) is possible on ata using H.323 with CCM.
Link isnt working.
Brandon,
You can simply remove /partner from the link and it should work. Try this one:
Hope this helps.
Brandon
