I have a ICM 7.5 with CVP 7.0 environment and I am currently having an issue where I am using the canned Webservice element in a VXML/Studio application and it is failing to pass session variable data to the web service in the "Request" although the same data is able to pass if it is hard coded in the "Request" section.
The issue appears to be not a web service issue since the hard coded data is working.
When dynamic session variables are nested within applications is the code somehow altered that prohibits webservices from funtioning normally?
Why would hard-coded variables work?
Thanks in advance.
