09-26-2013 03:36 PM
Hi guys,
I really don't understand what's going on. Maybe I'm wrong, maybe not. But.
I got a call on my voice-port 0/2/0. But my cisco matches the wrong dial-peer. This dial-peer matches by trunk group "common" which has port 0/0/1-0/0/3 (0/2/0 is not a member of the trunk group). Is it bug or feature?
cnx-rr01#sh voice call st
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
0xAD 152D 0x4AD5FF38 0/2/0 0/1:1 4255550103 g711ulaw 102/501
1 active call found
cnx-rr01#sh voice port s | i fxo
0/0/0 -- fxo-ls up dorm idle on-hook y
0/0/1 -- fxo-ls up dorm idle on-hook y
0/0/2 -- fxo-ls up dorm idle on-hook y
0/0/3 -- fxo-ls down down idle on-hook y
0/2/0 -- fxo-ls up up idle off-hook y
0/2/1 -- fxo-ls up dorm idle on-hook y
0/2/2 -- fxo-ls up dorm idle on-hook y
0/2/3 -- fxo-ls down down idle on-hook y
cnx-rr01#sh run | sec dial-peer voice 102
dial-peer voice 102 pots
trunkgroup common
tone ringback alert-no-PI
description ToPSTN
translation-profile incoming IN
translation-profile outgoing OUT00
preference 10
destination-pattern 9T
forward-digits all
cnx-rr01#sh trunk group common
Trunk group: common
Description:
trunk group label: common
Translation profile (Incoming):
Translation profile (Outgoing):
LPCOR (Incoming):
LPCOR (Outgoing):
Preemption is disabled (by default)
Hunt Scheme is round-robin
Max Calls (Incoming): NOT-SET (Any) 4 (Voice) NOT-SET (Data)
Max Calls (Outgoing): NOT-SET (Any) 4 (Voice) NOT-SET (Data)
Max Calls (MixTotal): NOT-SET (Any) 4 (Voice) NOT-SET (Data)
Retries: 0
Trunk 0/0/1 Preference DEFAULT
Member Timeslots : 1
Total channels available : 1
Data = 0, Voice = 0, Modem = 0, Pending = 0, Free = 1
Trunk 0/0/2 Preference DEFAULT
Trunk 0/0/3 Preference DEFAULT
Total channels available : 0
Data = 0, Voice = 0, Modem = 0, Pending = 0, Free = 0
Total calls for trunk group: Data = 0, Voice = 0, Modem = 0
Pend = 0, Free = 2
advertise_flag 0x00000040, capacity timer 25 sec tripl_config_mask 0x00000000
AC_curr 2, FD_curr 0, SD_curr 0
succ_curr 19 tot_curr 19
succ_report 19 tot_report 19
changed 1 replacement position 0
Current trunk : 0/0/1
09-26-2013 11:20 PM
Can you post the voice-port configuration?
09-27-2013 12:18 PM
Hi Russel,
Sure:
cnx-rr01#sh run | sec voice-port 0/2/0
voice-port 0/2/0
supervisory custom-cptone CN-BELLCORE
cptone CN
timeouts call-disconnect 1
timeouts wait-release 1
connection plar opx 914255550103
description +86 400 XXXXXXX - Support IVR
station-id name China Support
station-id number +86XXXXXXXXXX
caller-id enable
10-02-2013 11:52 PM
Guys, do you have any thoughts by the chance?
