Odd matched dial-peer on incoming call
pavelsh_ucs
Hi guys,
I really don't understand what's going on. Maybe I'm wrong, maybe not. But.
I got a call on my voice-port 0/2/0. But my cisco matches the wrong dial-peer. This dial-peer matches by trunk group "common" which has port 0/0/1-0/0/3 (0/2/0 is not a member of the trunk group). Is it bug or feature?
cnx-rr01#sh voice call st
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    MLPP Dial-peers
0xAD       152D 0x4AD5FF38 0/2/0            0/1:1   4255550103 g711ulaw 102/501
1 active call found
cnx-rr01#sh voice port s | i fxo
0/0/0           --  fxo-ls      up    dorm idle     on-hook  y
0/0/1           --  fxo-ls      up    dorm idle     on-hook  y
0/0/2           --  fxo-ls      up    dorm idle     on-hook  y
0/0/3           --  fxo-ls      down  down idle     on-hook  y
0/2/0           --  fxo-ls      up    up   idle     off-hook y
0/2/1           --  fxo-ls      up    dorm idle     on-hook  y
0/2/2           --  fxo-ls      up    dorm idle     on-hook  y
0/2/3           --  fxo-ls      down  down idle     on-hook  y
cnx-rr01#sh run | sec dial-peer voice 102
dial-peer voice 102 pots
trunkgroup common
tone ringback alert-no-PI
description ToPSTN
translation-profile incoming IN
translation-profile outgoing OUT00
preference 10
destination-pattern 9T
forward-digits all
cnx-rr01#sh trunk group common
Trunk group: common
        Description:
        trunk group label: common
        Translation profile (Incoming):
        Translation profile (Outgoing):
        LPCOR (Incoming):
        LPCOR (Outgoing):
        Preemption is disabled (by default)
        Hunt Scheme is round-robin
        Max Calls (Incoming):   NOT-SET (Any)   4 (Voice)       NOT-SET (Data)
        Max Calls (Outgoing):   NOT-SET (Any)   4 (Voice)       NOT-SET (Data)
        Max Calls (MixTotal):   NOT-SET (Any)   4 (Voice)       NOT-SET (Data)
        Retries: 0
        Trunk 0/0/1     Preference DEFAULT
                Member Timeslots : 1
                Total channels available : 1
                Data = 0, Voice = 0, Modem = 0, Pending = 0, Free = 1
        Trunk 0/0/2     Preference DEFAULT
        Trunk 0/0/3     Preference DEFAULT
                Total channels available : 0
                Data = 0, Voice = 0, Modem = 0, Pending = 0, Free = 0
        Total calls for trunk group: Data = 0, Voice = 0, Modem = 0
                                     Pend = 0, Free = 2
        advertise_flag 0x00000040, capacity timer 25 sec tripl_config_mask 0x00000000
        AC_curr 2, FD_curr 0, SD_curr 0
        succ_curr 19 tot_curr 19
        succ_report 19 tot_report 19
        changed 1 replacement position 0
        Current trunk : 0/0/1
rhopkins
Can you post the voice-port configuration?
Hi Russel,
Sure:
cnx-rr01#sh run | sec voice-port 0/2/0
voice-port 0/2/0
supervisory custom-cptone CN-BELLCORE
cptone CN
timeouts call-disconnect 1
timeouts wait-release 1
connection plar opx 914255550103
description +86 400 XXXXXXX - Support IVR
station-id name China Support
station-id number +86XXXXXXXXXX
caller-id enable
Guys, do you have any thoughts by the chance?
