one side voice receive in cisco ip phone
manodsaini
two location ........dera bassi and chd......dial number from dera bassi to chd.....chd receive my voice but i cannot receive voice chd...so tell me... whts problem.......please provide me best to best answer immediatly......
thanking you
David Hailey
You need to first check your routing.  One-way audio is often indicative of a routing issue where the one side of the call has audio path to the other end but not vice versa.  After the call is setup, both IP phones need to have direct connectivity to one another because RTP streams flow directly between endpoints.
Hailey
