PGW 2200 - Maximum Number of SS7 Links Supported
ATINC BAYTAN
What is the maximum number of SS7 links supported by single PGW2200 node?
Thanks in advance.
PGW2200 Node supports max. 192 SS7 links.
Pl rate if info is helpful. Thanks
How many CICs its support in both type of modes.
Amit
Max. no. of CICs you can create in your PGW is equal to the no. of TDM ports been provisioned.
You can see the TDM Ports provisioned using the CLI
< rtrv-lics:all
Thanks. Pl rate if info is useful.
I mean to say the Max.no. of possible CICs is equal to the No.of TDM Ports Entitled.
Thanks.
