tareqrebhi
Beginner
PGW2200 has a command PGW2200 has a command PGW2200 has a command
dear,
do PGW2200 has a command to show the running configuration?
like:
show ruu.
i need to see all configuration at my PGW.
26 REPLIES 26
hi,
what commands should use at NAS to limit carrier's calls or let say Voice traffic?
can give example please?
thank you...
my AS5400 IOS is Version 12.3(10f)
You will need to do this at the PGW. Must be on at least version 9.6(1). See here...
http://www.cisco.com/en/US/docs/voice_ip_comm/pgw/9/feature/module/9.6_1_/FMCallLm.html
it is very useful doc. but it didn't solve my problem.
that i need following example:
carrier 1 (IP is 88.23.54.2) just to use only 10 chanels from my first E1.
carrier 2 (IP is 129.42.167.7) just to use only 10 chanels from my first E1.
did you get my point?
i saw in this doc :
this example with title (Applying Call Limiting to an MGCP Gateway ):
i see IP addrress , can i use thi example for my case?
thank you.
i need to configure IVR at AS5400 i did :
call application voice TCLware.1.2.3 tftp://55.55.54.11/TCLware.1.2.3/clid_4digits_npw_3.1.1.0.tcl 1
call application voice TCLware.1.2.3 language 1 en
call application voice TCLware.1.2.3 uid-len 8
call application voice TCLware.1.2.3 pin-len 6
call application voice TCLware.1.2.3 set-location en 0 tftp://55.55.54.11/TCLware.1.2.3/prompts/en
but when i put application TCLware.1.2.3 the calls for outbound are not pass.
any help?
dear
this command is not acceptable at NAS:
rule 1 /\(^63\)/ /962\1/
Incorrect format for Translation Match Pattern
any help?
Please send show ver from nas and the output of this when you paste it in your NAS:
conf t
voice translation-rule 1
ok rule 1 /\(^63\)/ /962\1/
is true i am so sorry.
Dear thank you much for your helping .
Now i am following our talking i will give the feed back for the results you are great.
tareq.
scpage
Beginner
You can export the config using the following command via mml:
prov-exp:all:dirname="yourdirnamehere"
Once the command has completed..exit mml
cd /opt/CiscoMGC/etc/cust_specific/yourdirnamehere
The files in that directory contain your config...viewable as text.
Thank you for your help.
i have this question, My AS5400 send CDR for my Billing System ... but the calls or CDR for incoming national calls (Mobile & Fix)to my network are coming without prefix for our local and national calls which is 00962, on other hand calls from my network to other local carriers include the prefix 00962...is it clear?
All other International calls include correct prefixes no problem.
Example:
Local Mobile= 0777223344
Local Fix= 064536543
my network= 063000000
Jordan Prefix= 962
Now call from o777223344 or 064536543
to 063000000 has the error where CDR at Billing system without 00962 it is only 063000000 it is not 96263000000 this take us that call comes from Phillipines Fix 63 and not from my network 63000000.
Remember calls from 063000000 to any destination is right prefix.
any help please at AS5400 or PGW2200??
