12-29-2005 05:48 AM
In our system I need to increase maximum number of digits that are sent to other STPs. I inserted TmaxDigits=32 and OD32DigitSupport=1 to SS7 paths and to trunk group configuration.
Now MGC sends out more than 16 digits but I get Cause =111, Protocol Error messages.
14:20:46.517204 0-001-7[00015] 0-003-6[00030] ITU ISUP. -> IAM (01) CIC=00377 CDPN=109930078636020615F CGPN=7112278
SLS=09 Pr:0 Ni:NTL
14:20:46.627141 0-003-6[00030] 0-001-7[00015] ITU ISUP. -> REL (0c) CIC=00377 Cause 111 = Protocol Error, Unspecified
What else should I change to get this thing working?
Solved! Go to Solution.
12-29-2005 04:36 PM
1. Have you configured "overlap" mode?
2. Are you sure that the other side is configured to accept 32 digit numbers?
12-29-2005 04:36 PM
12-30-2005 01:00 AM
http://www.cisco.com/en/US/products/hw/vcallcon/ps2152/products_tech_note09186a00802076dc.shtml
Is this the right document to look for when configuring overlaping mode or did you mean something else?
01-02-2006 01:58 AM
Got it working after I removed 32 digit support and added TOverlap=1, TmaxDigits=32.
After these changes PGW started to send longer than 16-digit number in two messages IAM+SAM.
I think that other end just did not accept 32-digits in IAM messages.
01-02-2006 02:37 AM
That is why I told you to check with the other side first. Otherwise you are working 'on blind'
