02-05-2005 03:28 AM
Dear all,
I am running voip over 64 k Leased line between 2 locations. I am using E & M ports for voip in 1700 series routers at both the ends.
The configuration in routers is ok in both the routers.
And thesame configuration is made in both the routers. But On one side the voice quality is not good, while on other side the quality of voice is ok.
Can anybody suggest me the solution. I have just made basic configuration at both the ends. I have not fine tuned voice.
Tushar
02-05-2005 05:52 AM
Can you post your configs?
Aaron
02-08-2005 06:38 AM
Have you enabled QoS on both ends and checked Codec settings?
