Problems with SIP telephony configuration between routers 3925?
jmcartas_18
I am currently implementing SIP telephony in the configuration of my routers, and I have configured the voice-register-global, in the telephony-service part of the SIP enabled, I could log my standard SIP phones without problem .. when I make internal calls there is no problem calls are made well, but when I want to make a call from a phone that is in the router A to another Router B can not make the call first I assumed shows Ring Out ​​but after unknown number rings a few seconds ..
It is the first time I work with SIP phones so I really do not understand what is happening.
Annex Run my Sh ...
HubCoatza#sh run
Building configuration...
Current configuration : 10325 bytes
! Last configuration change at 11:41:03 MX Thu Dec 26 2013 by user2
! NVRAM config last updated at 11:41:06 MX Thu Dec 26 2013 by user2
version 15.1
hostname HubCoatza
boot-start-marker
boot-end-marker
aaa new-model
aaa session-id common
clock timezone MX -6 0
no ipv6 cef
no ip source-route
ip cef
ip dhcp excluded-address 192.168.100.1 192.168.100.253
ip dhcp excluded-address 192.168.101.254
ip dhcp pool Voice
import all
network 192.168.20.0 255.255.255.0
default-router 192.168.20.254
option 150 ip 192.168.20.254
lease infinite
ip dhcp pool Datos-Red
network 192.168.101.0 255.255.255.0
default-router 192.168.101.254
ip dhcp pool Data
network 192.168.16.0 255.255.255.0
default-router 192.168.16.254
domain-name icsicorp
dns-server 192.168.1.22
ip dhcp pool Data2
network 192.168.3.0 255.255.255.0
default-router 192.168.3.254
crypto pki trustpoint TP-self-signed-595947439
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-595947439
revocation-check none
rsakeypair TP-self-signed-595947439
crypto pki certificate chain TP-self-signed-595947439
certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 35393539 34373433 39301E17 0D313331 31313530 30353334
  385A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3539 35393437
  34333930 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  C507C03B 4FBCC60D 85A6FDE7 A3FD55A6 CE9AB147 61E4BA9C 0D046767 F33908A9
  73355DF6 DA6C4AE4 D1DA47B0 FBE4F73D E4612CE2 1F3862C3 6ED23F3B 9C83921F
  E078C9D4 AA4CF4F1 7DBABEC2 F29B59F7 6900CF0B 0B8D8754 46D9C138 D96E5C1A
  182C5D43 A373C177 B78440DF D25A1923 B23B6F03 F79D82D2 02973902 4087076B
  02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
  23041830 16801495 3FC9C2D1 D786933B F3A8B681 CED5D0B5 39B02330 1D060355
  1D0E0416 0414953F C9C2D1D7 86933BF3 A8B681CE D5D0B539 B023300D 06092A86
  4886F70D 01010505 00038181 0030B27A 566EBE60 146146C6 4A9BA5A5 65ED23E4
  30E454A3 E805B679 2F995B2F 51AE493E 542FBF50 9614C116 678655F9 00179985
  E45B60AD 5B2E9583 6E66F72F C93AAB9E 81EA8F02 301063A4 8B8238D8 F24218F2
  0AB2A07D 1F30C921 9121F806 FFC65705 61335D51 1D8C9DEE B2FF0589 DE0F1363
  3E1A4286 BB3B2200 A3584ADF 77
        quit
voice-card 0
voice rtp send-recv
voice service voip
no ip address trusted authenticate
dtmf-interworking rtp-nte
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
modem passthrough nse codec g711ulaw
sip
  session transport tcp
  registrar server
  sip-profiles 1
voice class sip-profiles 1
request REINVITE sdp-header Audio-Attribute modify "sendonly" "sendrecv"
voice iec syslog
voice register global
mode cme
source-address 192.168.20.254 port 5060
max-dn 10
max-pool 10
load 8961 sip8961.9-2-2SR1-9
authenticate register
tftp-path flash:
create profile sync 0007958157206141
voice register dn  1
number 5000
allow watch
name Phone 4
label Ext. 5000
voice register pool  1
id mac 8478.ACE6.D69F
type 8961
number 1 dn 1
cor incoming User-Nacional default
dtmf-relay sip-notify
username icsi password icsi
codec g711ulaw
voice hunt-group 2 sequential
list 2001,2002,5000
timeout 10
pilot 2004
license udi pid C3900-SPE200/K9 sn FOC16400V86
license accept end user agreement
license boot module c3900e technology-package uck9
hw-module sm 2
username icsicorp privilege 15 password 0 1cs1c0rp
username angel privilege 15 secret 4 UQEMqulDiyvAZYsaf9mfsinS71XeAUEVlBy99QRtokk
username user2 privilege 15 secret 4 M0LFXyG8jIIKVGXlWc9WNRqMp04b02eUbq4nEL.t.OA
username dmvpn privilege 15 secret 4 AoHyJvorW4qwD0VEEv6oO3Znn.4JcJ8pSoqoLpQHQds
redundancy
crypto ipsec transform-set TS esp-3des esp-md5-hmac
crypto ipsec profile protect-gre
set security-association lifetime seconds 86400
set transform-set TS
interface Loopback102
ip address 192.168.102.254 255.255.255.0
interface Loopback200
ip address 192.168.200.254 255.255.255.0
interface Tunnel0
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip next-hop-self eigrp 10
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip nhrp holdtime 600
ip nhrp registration timeout 30
no ip split-horizon eigrp 10
tunnel source 192.168.101.254
tunnel mode gre multipoint
tunnel protection ipsec profile protect-gre
interface GigabitEthernet0/0
description LAN-Network
ip address 192.168.101.254 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
description WAN-Network
ip address 192.168.100.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2
ip address 192.168.16.254 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2.2
encapsulation dot1Q 20
ip address 192.168.20.254 255.255.255.0
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.20.254
interface GigabitEthernet0/3
description Link to RouterTelefonia
ip address 192.168.3.254 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet2/0
ip address 192.168.30.254 255.255.255.0
interface GigabitEthernet2/1
description Internal switch interface connected to EtherSwitch Service Module
switchport mode trunk
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
ip http server
ip http authentication aaa
ip http secure-server
ip route 172.16.2.0 255.255.255.0 GigabitEthernet0/1
ip route 192.168.201.0 255.255.255.0 GigabitEthernet0/1
ip route 192.168.202.0 255.255.255.0 GigabitEthernet0/1
nls resp-timeout 1
cpd cr-id 1
tftp-server flash:sip8961.9-2-2SR1-9.loads
tftp-server flash:skern8961.022809R2-9-2-2SR1-9.sebn
tftp-server flash:dkern8961.100609R2-9-2-2SR1-9.sebn
tftp-server flash:kern8961.9-2-2SR1-9.sebn
tftp-server flash:rootfs8961.9-2-2SR1-9.sebn
tftp-server flash:sboot8961.031610R1-9-2-2SR1-9.sebn
control-plane
mgcp profile default
sccp local GigabitEthernet0/2.2
sccp ccm 192.168.20.254 identifier 1 version 4.0
sccp ip precedence 3
sccp
sccp ccm group 2
bind interface GigabitEthernet0/2.2
associate ccm 1 priority 1
associate profile 4 register confprof
sccp ccm group 1
dspfarm profile 1 transcode
description RECURSOS DE TRANSCODE
associate application SCCP
shutdown
dspfarm profile 4 conference
description ICSI
shutdown
dial-peer cor custom
name Internas
name Local
name Nacional
name Celular
name LocalFAC
name NacionalFAc
name CelularFAC
dial-peer cor list LlamadasInternas
member Internas
dial-peer cor list LlamadasLocales
member Local
dial-peer cor list LlamadasNacionales
member Nacional
dial-peer cor list LlamadasCelular
member Celular
dial-peer cor list LlamadasCelularFAC
member CelularFAC
dial-peer cor list LlamadasNacionalesFAC
member NacionalFAc
dial-peer cor list LlamadasLocalesFAC
member LocalFAC
dial-peer cor list User-Internas
member Internas
dial-peer cor list User-Local
member Internas
member Local
dial-peer cor list User-Nacional
member Internas
member Local
member Nacional
member Celular
dial-peer voice 100 voip
corlist outgoing LlamadasCelular
destination-pattern 9[044].....
session protocol sipv2
session target ipv4:192.168.100.2
codec g711alaw
no vad
dial-peer voice 300 voip
corlist outgoing LlamadasNacionales
destination-pattern 92112345
codec g711alaw
no vad
dial-peer voice 400 voip
corlist outgoing LlamadasLocales
destination-pattern 4...
incoming called-number 4...
voice-class sip bind control source-interface GigabitEthernet0/2.2
voice-class sip bind media source-interface GigabitEthernet0/2.2
dtmf-relay rtp-nte h245-alphanumeric
codec g711ulaw
no vad
sip-ua
retry invite 2
gatekeeper
shutdown
telephony-service
sdspfarm units 2
sdspfarm tag 1 confprof
conference hardware
max-ephones 10
max-dn 10
ip source-address 192.168.20.254 port 2000
auto assign 1 to 5
system message Corporativo ICSI
cnf-file location flash:
load 7970 cmterm-7970_7971-sccp.9-2-1
max-conferences 8 gain -6
transfer-system full-consult
ephone-dn  1
number 2000
label Phone 1
description Ext 2000
name Phone 1
ephone-dn  2
number 2001
pickup-group 2
label Phone 2
description Ext 2001
corlist incoming User-Local
ephone-dn  3
number 3001
label Phone 3
description Ext 3001
ephone-dn  4
number 3002
label Phone 3
description Ext 3002
ephone-dn  5
number 2002
pickup-group 2
label phone 4
description Ext. 2002
corlist incoming User-Nacional
ephone  1
device-security-mode none
mac-address 0014.1C31.5A8A
type 7912
button  1:1
ephone  2
mac-address 0014.1C31.577B
type 7912
button  1:2
ephone  3
mac-address 0013.80CE.8D24
max-calls-per-button 2
type ata
button  1:3
ephone  4
mac-address 1380.CE8D.2401
type ata
button  1:4
ephone  5
mac-address 0013.1A59.23BA
type 7970
button  1:5
line con 0
line aux 0
line 130
no activation-character
no exec
transport preferred none
transport input all
transport output none
stopbits 1
flowcontrol software
line vty 0 4
password icsicorp
transport input all
scheduler allocate 20000 1000
end
RouterTelefonia#sh run
Current configuration : 10218 bytes
! Last configuration change at 14:32:59 MX Tue Dec 24 2013
version 15.2
hostname RouterTelefonia
boot-start-marker
boot system flash:c3900e-universalk9-mz.SPA.152-4.M5.bin
boot-end-marker
enable password icsi
no aaa new-model
no ip source-route
ip cef
ip dhcp excluded-address 192.168.201.1 192.168.201.100
ip dhcp excluded-address 192.168.201.201 192.168.201.254
ip dhcp pool Spoke-Data
ip dhcp pool Voice2
import all
network 192.168.2.0 255.255.255.0
default-router 192.168.2.254
option 150 ip 192.168.2.254
lease infinite
ip dhcp pool Red-Datos
network 192.168.201.0 255.255.255.0
default-router 192.168.201.254
ip dhcp pool Data
network 192.168.15.0 255.255.255.0
default-router 192.168.15.254
no ipv6 cef
crypto pki trustpoint TP-self-signed-1463471945
subject-name cn=IOS-Self-Signed-Certificate-1463471945
rsakeypair TP-self-signed-1463471945
crypto pki certificate chain TP-self-signed-1463471945
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31343633 34373139 3435301E 170D3133 31323232 30323237
  32375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 34363334
  37313934 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100E070 976763E1 283D29B4 55D96CEB 85E34D05 40369899 78542F6E A2873CF9
  028DF9A6 689A3F11 80A0E204 19323969 6CEB7534 8AAB85C9 F36E8EC9 8348B810
  D8178B98 496042CB 9BE20C54 0B8E12BB 27D07C5C 6C20E28F 53A0314E F2F68EE9
  63267813 338B144E 99967FC7 EC1991D5 02D63B13 B496E120 8BF46426 48A2F072
  7B9B0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 142AA6CA 423EFDFD EFB33AAF 207B1D3C EAF630D8 8B301D06
  03551D0E 04160414 2AA6CA42 3EFDFDEF B33AAF20 7B1D3CEA F630D88B 300D0609
  2A864886 F70D0101 05050003 818100BE 60537977 808226F3 91FB1208 DBDC714A
  8C47A252 3F34402F DD2F9A92 901B6E50 2668AD91 8CB09AD8 14129D5D C90CD8B0
  19F8809B 6DBEA675 91F298D0 DB43BB89 1267DD91 6B29A16D A2EF66B7 9992B407
  16192EEB F9844F8E 1F167D16 203A48F0 DC603E04 62DCDC55 30B288F0 AE4113E0
  B96403CE 2E1838E8 F3FA8179 8846DF
        quit
voice-card 0
codec complexity high
dspfarm
dsp services dspfarm
voice rtp send-recv
voice service voip
h323
sip
  bind control source-interface GigabitEthernet0/1.2
  bind media source-interface GigabitEthernet0/1.2
  registrar server
voice iec syslog
mode cme
source-address 192.168.2.254 port 5060
max-dn 10
max-pool 10
tftp-path flash:
create profile sync 0001103516586987
conference hardware
voice hunt-group 1 parallel
list 4000,4001,4002
timeout 10
pilot 4004
license udi pid C3900-SPE200/K9 sn FOC16400V7B
hw-module pvdm 0/2
hw-module sm 2
username icsicorp privilege 15 secret 4 UQEMqulDiyvAZYsaf9mfsinS71XeAUEVlBy99QRtokk
redundancy
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key firewall.cx address 0.0.0.0
mode tunnel
interface Loopback201
no ip address
interface Loopback202
ip address 192.168.202.254 255.255.255.0
interface Tunnel0
ip address 10.10.10.2 255.255.255.0
no ip redirects
ip nhrp map multicast 192.168.101.254
ip nhrp map 10.10.10.1 192.168.101.254
ip nhrp nhs 10.10.10.1
tunnel source 192.168.100.2
description Link to HubCoatza$ES_LAN$
ip address 192.168.1.200 255.255.255.0
duplex auto
speed auto
ip address 192.168.15.254 255.255.255.0
duplex auto
speed auto
ip address 192.168.2.254 255.255.255.0
h323-gateway voip bind srcaddr 192.168.2.254
ip address 192.168.201.254 255.255.255.0
duplex auto
speed auto
ip address 192.168.100.2 255.255.255.252
duplex auto
speed auto
ip address 192.168.10.254 255.255.255.0
no ip address
interface Vlan1
no ip address
ip http server
ip route 172.16.1.0 255.255.255.0 GigabitEthernet0/3
ip route 192.168.101.0 255.255.255.0 GigabitEthernet0/3
ip route 192.168.102.0 255.255.255.0 GigabitEthernet0/3
ip route 192.168.103.0 255.255.255.0 GigabitEthernet0/3
ip route 192.168.200.0 255.255.255.0 GigabitEthernet0/3
nls resp-timeout 1
cpd cr-id 1
control-plane
voice-port 0/0/0
voice-port 0/0/1
connection plar opx immediate 2002
voice-port 0/0/2
connection plar opx immediate 4002
voice-port 0/0/3
sccp local GigabitEthernet0/1.2
sccp ccm 192.168.2.254 identifier 1 version 4.0
sccp
sccp ccm group 1
sccp ccm group 2
bind interface GigabitEthernet0/1.2
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 5
description ICSI
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
name Internas
name Local
name Nacional
name Celular
name LocalFAC
name NacionalFAc
name CelularFAC
member Internas
member Local
member Nacional
member Celular
member CelularFAC
member NacionalFAc
member LocalFAC
member Internas
member Internas
member Local
member Internas
member Local
member Nacional
member Celular
corlist outgoing LlamadasInternas
destination-pattern 3...
session target ipv4:192.168.100.1
incoming called-number 3...
codec g711alaw
no vad
dial-peer voice 10 pots
port 0/0/2
forward-digits 8
dial-peer voice 20 pots
port 0/0/1
forward-digits 9
dial-peer voice 200 voip
destination-pattern 2...
incoming called-number 2...
voice-class sip bind control source-interface GigabitEthernet0/1.2
voice-class sip bind media source-interface GigabitEthernet0/1.2
codec g711ulaw
ip qos dscp cs3 media
ip qos dscp cs3 signaling
no vad
gatekeeper
shutdown
telephony-service
sdspfarm units 2
conference hardware
max-ephones 10
max-dn 10
ip source-address 192.168.2.254 port 2000
auto assign 1 to 5
load ata ATA030204SCCP090202A.zup
web admin system name icsi secret 5 $1$8l5t$lza4RBKyZcz5UC0S1QwYg1
dn-webedit
transfer-pattern 1...
transfer-pattern 4...
create cnf-files version-stamp 7960 Dec 17 2013 13:18:22
ephone-dn  1
number 4000
pickup-group 1
label Phone 1
description Ext. 4000
name Phone 1
corlist incoming User-Internas
ephone-dn  2
number 4001
pickup-group 1
label Phone 2
description Ext. 4001
name Phone 2
ephone-dn  3
number 4002
pickup-group 1
label Phone 2
description Ext. 4002
name Phone 3
ephone  1
mac-address 0014.1C31.57F1
type 7912
button  1:1
ephone  2
mac-address 0014.1C31.59DA
type 7912
button  1:2
ephone  3
mac-address E811.3289.7CD6
type CIPC
button  1:3
line con 0
line aux 0
line 130
no exec
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password icsicorp
login
transport input all
end
Greetings and thanks
0 Replies 0
