I have a VPN Point to Multipoint, each point is using two VoIP port.
The core is using 6 voice ports, the problem is that the last two port that I added they aren?t working.
I have the same configuration for all:
A) voice-port 3/3
timeouts call-disconnect 1
connection plar 8157
B) dial-peer voice 100 voip
destination-pattern 8157
session target ipv4:X.X.X.X
dtmf-relay h245-alphanumeric
no vad
C) dial-peer voice 10 pots
port 3/3
forward-digits all
prefix ,,
But, these two last port send a busy tone, i can?t dial.
The users call to these lines, they are sending to VPN locations, you can see next:
Extension(8157)-PBX-Router-VPN-Router-Extension(8157)
Do you know where the problem is ?
