10-07-2012 09:32 PM
Hi Experts ,
We have confiured QoS on 3750 switches where ip telephones are connected.we have created access-list for SIP servers and audio codec servers and calling this access-list in policy map which was created on the router.we have done shaping on the router which allows bandwidth equal to capacity of the link.
Below is the configuration done on the switch and router.
Router config of QoS :
class-map match-all color-t
match access-group 133
class-map match-all class-j
match ip precedence 5
class-map match-all class-n
match ip precedence 1
class-map match-all class-t
match ip precedence 4
class-map match-all color-j
match access-group 135
class-map match-all class-bi
match ip precedence 0
class-map match-all color-bi
match access-group 130
policy-map colorization
class color-j
set precedence 5
class color-t
set precedence 4
class color-bi
set precedence 0
class class-default
set precedence 1
policy-map qos-mpls
class class-t
bandwidth percent 25
class class-j
priority percent 25
class color-bi
bandwidth percent 15
class class-default
fair-queue
random-detect
policy-map to-mpls
description parent policy
class class-default
shape average 2000000
service-policy qos-mpls
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos map ip-prec-dscp 0 8 16 26 32 46 48 56
mls qos srr-queue input bandwidth 90 10
mls qos srr-queue input threshold 1 8 16
mls qos srr-queue input threshold 2 34 66
mls qos srr-queue input buffers 67 33
mls qos srr-queue input cos-map queue 1 threshold 2 1
mls qos srr-queue input cos-map queue 1 threshold 3 0
mls qos srr-queue input cos-map queue 2 threshold 1 2
mls qos srr-queue input cos-map queue 2 threshold 2 4 6 7
mls qos srr-queue input cos-map queue 2 threshold 3 3 5
mls qos srr-queue input dscp-map queue 1 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue input dscp-map queue 1 threshold 3 32
mls qos srr-queue input dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2 33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2 49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos srr-queue output dscp-map queue 1 threshold 3 40 41 42 43 44 45 46 47
mls qos srr-queue output dscp-map queue 2 threshold 3 24 25 26 27 28 29 30 31
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 3 threshold 3 32 33 34 35 36 37 38 39
mls qos srr-queue output dscp-map queue 4 threshold 1 8
mls qos srr-queue output dscp-map queue 4 threshold 2 9 10 11 12 13 14 15
mls qos srr-queue output dscp-map queue 4 threshold 3 0 1 2 3 4 5 6 7
mls qos queue-set output 1 threshold 1 138 138 92 138
mls qos queue-set output 1 threshold 2 138 138 92 400
mls qos queue-set output 1 threshold 3 36 77 100 318
mls qos queue-set output 1 threshold 4 20 50 67 400
mls qos queue-set output 2 threshold 1 149 149 100 149
mls qos queue-set output 2 threshold 2 118 118 100 235
mls qos queue-set output 2 threshold 3 41 68 100 272
mls qos queue-set output 2 threshold 4 42 72 100 242
mls qos queue-set output 1 buffers 10 10 26 54
mls qos queue-set output 2 buffers 16 6 17 61
mls qos
QoS configuration on the switch :
mls qos
Trunk link created between switch and router.
We did testing for SIP proxy server and audio codec and obsered that "Packet loss and Full/Half duplex Issue' are happening.
What could be the reason for packet loss.what else we can check on the router and switch.Please elaborate below things.
Rate limiting behaviour is detected.
full duplex / half duplex conflict dected.
10-09-2012 08:56 AM
You will have better results by removing all and any QoS configuration.
