08-14-2007 12:45 PM
Hi, I need to set QOS for UDP ports 5004 and 5440-5445. I would like to just do it by the port number and avoid lists, ip addresses, macs and all that. Is there a way to do this?
Roger
08-16-2007 01:10 PM
You can turn on NBAR, if your IOS supports it and see if it picks up the application. If not, you'll need to use acl to pick out the ports.
John
Log in to Community
