recovery on timer expiry for R2
surenx_cisco
Can anyone tell me how to increase the value of the timer for R2 connection that my calls wouldn't get dropped after 6 seconds of inactivity.
Thanks in Advance.
paolo bevilacqua
Does the call connects then drops after 6 secs ?
Or which kind of inactivity are your referring to?
It is happening for incoming or outgoing calls ?
It is possible that something is not correct with the E1 R2 "handshake" as applicable to your country/telco, hence the call drop.
