12-04-2012 09:46 AM
Cisco CME to Cisco UBE Options ping no-worky....
Did anyone get SIP options pings working on a pure Cisco router (UBE to UBE and UBE to CME) environment? I have a pure Cisco 15.1 network that we are playing with option pings on. I see pings go out and 200 OK responses, but dial-peers are still busying out. Have tried both default and example settings from Cisco UBE deployment guides. Routers are working with options pings from external ITSPs, so know options replies are working and are supported. So, what's the magic sauce on Cisco IOS 15.1 for SIP options-keepalive?
dial-peer voice 40221 voip
corlist outgoing peer-internal
description \\\ 4385 - 4389 \\\
translation-profile outgoing ToCUCME_NANP_PrefixedE164
preference 1
destination-pattern 438[5-9]
session protocol sipv2
session target ipv4:10.5.5.1
voice-class sip early-offer forced
voice-class sip options-keepalive up-interval 12 down-interval 65 retry 3
dtmf-relay rtp-nte
fax-relay ecm disable
no fax-relay sg3-to-g3
fax rate 14400
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-throug
no vad
12-04-2012 09:49 AM
There are no firewalls or NAT between and when using "debug ccsip message" we see option sent and received and replies on both sides.
05-20-2013 12:29 PM
At least I don't feel that bad now - nearly 600 views with no solution. We validated this issue exist on 15.2 also.
