SIP trunk and modem call termination
mirmer
is it possible to terminate modem calls (v.90) that comes via a SIP trunk as G.711 on a router ?
I think the SIP Trunk termination is not the problem, but what do I have to configure to get the modem call to IP data ?
Does it work on only one router (e.g. C29xx or 39xx) ?
I just found some information about modem passthrough, but I think that is not my solution.
Mike
Jaime Valencia
This is the Video Over IP forum, might want to move this to a relevant area.
java
if this helps, please rate
rusfatman
What kind of data you want to recieve from that call? Do you want to create a pool of modems? What do you want to do with calls?
