soft block the T1 circuit
anitachoi3
I have two AS5400 with 12 T1 cricuits. I would like to block the T1 circuits of one box for maintenance.
Does it have a command to block the T1 circuit after the voice call is completed? It is not necessary to block the channels one by one.
rdgs
smahbub
Level 6
Level 6
You can take a specified channel or an entire PRI interface out of service or put it into one of the other states that is passed in to the switch. To do so, complete the following task in interface configuration mode:
"AS5350(config-controller)# isdn service dsl number b_channel 0 state state-value"---- Sets the entire PRI interface to the specified state.
Refer the following link for more information on blocking T1 circuits in AS5400:
http://www.cisco.com/en/US/docs/routers/access/as5350/software/configuration/guide/54bas3_ps501_TSD_Products_Configuration_Guide
