06-15-2010 07:16 PM
Hi there, i am trying to set up the following system
analog commander pbx ---> linksys8800 ---> internet
it seems to work fine when the internet is connected, but i would like it to failover and kick back onto the old ptsn line when the net is down.
i know this is possible with an asterix server but i dont know how to configure a normal old line on the spa8800? when i pull the ethernet cable it just sounds engaged.
i hope this is possible.
im a bit of a newbie as you can probably tell!. thanks in advance for your help.
06-16-2010 02:18 AM
Voice tab > Line page >
VoIP Fallback to PSTN section (SPA3102 and SPA8800)
On the SPA8800, these settings are configured on the Phone pages only.
Auto PSTN Fallback : If enabled, the ATA device automatically routes all calls to the PSTN gateway when the Line 1 proxy is down (registration failure or network link down).
The default is yes.
http://www.cisco.com/en/US/docs/voice_ip_comm/csbpvga/ata/administration/guide/ATA_AG_v3_NC-WEB.pdf
hope this helps
M.D.
06-16-2010 06:13 PM
thanks very much for your help. it seems to be half working but i sitll have an issue wth the net side of things,
When the power is removed from the spa8800 it failsover to the ptsn line well,
but when i remove just the ethernet, it doesnt want to failover, just gives me an engaged signal... any ideas?
i have set the following settings to the line page thinking this might help but doesnt seem to change.
Make Call Without Reg: yes
Ans Call Without Reg: yes
Register: no
All i am getting is an engaged signal when the net is down..
i assume it doesnt need to register with a device as it is analog.
is there something i am missing here?
thanks very much for your help. almost there!
