tcp reset
migi00000
I am trying a call from telephony server through Cisco gateway, but as I can see in wireshark trace went telephony server send TCP SYN, Cisco reset it, and all is failed. What I missed in configuration ?
thanks in advance
Cisco_AS5350XM_SIP#sh version
Cisco IOS Software, 5350 Software (C5350-IS-M), Version 12.4(17), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Sat 08-Sep-07 00:38 by prod_rel_team
ROM: System Bootstrap, Version 12.3(12r)PI6b, RELEASE SOFTWARE (fc1)
Entire call flow?
debug voip ccapi would help.
Is there any command to show active ports?
This debug doesn't get anything
thx
show ip tcp brief
show udp
I fixed problem.
thanks
