Translate a Called number depending on a Incoming Calling Number in a H.323 router
mariocscunha
Have a H.323 router with E1 R2 Digital PSTN Trunks. Need to change the called number, that is, change the called number of the incoming call based on the calling information. In other words need to selectively forward the incoming call to a different destination if that is from an specific person.
You can create a specific dial-peer which will match the incoming calling number (ANI). Under this DP you can configure a voice translation rule to change the called number.
Something like this:
dial-peer voice 1012 voip
description INCOMING CALLING with prefix 290
translation-profile incoming XLATE_B_NUM
answer-address 290
modem passthrough nse codec g711alaw
codec g711alaw
no vad
voice translation-profile XLATE_B_NUM
translate called 15
voice translation-rule 15
rule 1 /^\([0-9]\)/ /2299\1/
All incoming calls with a calling number 290xxx use the DP 1012.
The DP 1012 doesn't route the call but simply adds the prefix 2299 to the called number.
A second dial-peer uses the called number 2299xxx to route the call.
Regards.
