04-20-2011 03:47 AM
I have configured CUE and i can call from internal and can listen the greeting message. but when i call from any other pstn number to main line (2811 cisco router acting as h323 Voice Gateway) calls have been dropped.
I call from ip phone to pstn (outgoing is ok) but problem is in incoming call.
Any clue???
CONFIGURATION is as below
boot-start-marker
boot-end-marker
card type e1 0 2
logging message-counter syslog
enable secret 5 $1$7SY2$Zwgh/Il4qYxg9DOFHpST.1
no aaa new-model
clock timezone GMT 4
network-clock-participate wic 2
network-clock-select 1 E1 0/2/0
dot11 syslog
ip source-route
ip cef
no ip domain lookup
isdn switch-type primary-net5
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
sip
bind control source-interface Loopback101
bind media source-interface Loopback101
registrar server
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
voice register global
mode cme
source-address 10.1.211.1 port 5060
max-dn 100
authenticate register
voice-card 0
dspfarm
dsp services dspfarm
application
global
service alternate default
log config
hidekeys
controller E1 0/2/0
framing NO-CRC4
pri-group timeslots 1-10,16
ip address 10.1.211.1 255.255.255.192
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.1.211.1
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Integrated-Service-Engine1/0
ip unnumbered Loopback101
service-module ip address 10.1.211.62 255.255.255.192
service-module ip default-gateway 10.1.211.1
no keepalive
router eigrp 1
network 172.16.40.0 0.0.0.3
network 172.16.250.24 0.0.0.3
network 192.168.84.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.16.40.1
ip route 10.1.211.62 255.255.255.255 Integrated-Service-Engine1/0
ip route 172.16.250.12 255.255.255.252 172.16.250.25
ip route 172.16.250.28 255.255.255.252 172.16.250.25
no ip http server
no ip http secure-server
control-plane
call fallback active
voice-port 0/2/0:15
bearer-cap Speech
no ccm-manager fax protocol cisco
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp fax t38 ecm
sccp local Loopback101
sccp ccm 10.50.2.3 identifier 1 version 7.0
sccp ccm 10.50.2.4 identifier 2 version 7.0
sccp
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 10 pots
tone ringback alert-no-PI
description International
destination-pattern 900.T
fax rate disable
port 0/2/0:15
prefix 00
dial-peer voice 11 pots
description Emergency
destination-pattern 9600....
fax rate disable
port 0/2/0:15
prefix 600
dial-peer voice 12 pots
destination-pattern 9800....
fax rate disable
port 0/2/0:15
prefix 800
dial-peer voice 13 pots
description Mobile
destination-pattern 905........
fax rate disable
port 0/2/0:15
prefix 05
dial-peer voice 14 pots
description National
destination-pattern 90[234678].......
fax rate disable
port 0/2/0:15
prefix 0
dial-peer voice 15 pots
description Local
destination-pattern 9.......
fax rate disable
port 0/2/0:15
dial-peer voice 16 pots
fax rate disable
port 0/2/0:15
dial-peer voice 100 voip
description To CallManager Pub
preference 1
destination-pattern [789]..
voice-class codec 1
voice-class h323 1
session target ipv4:10.50.2.3
dtmf-relay h245-alphanumeric
req-qos guaranteed-delay audio
acc-qos guaranteed-delay audio
fax-relay ecm disable
fax rate 14400
fax nsf 000000
fax protocol pass-through g711ulaw
no vad
dial-peer voice 200 voip
description To CallManager Sub
huntstop
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:10.50.2.4
fax rate 14400
fax nsf 000000
no vad
gateway
timer receive-rtp 1200
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.1.211.1 port 2000
max-ephones 42
max-dn 144
line con 0
speed 115200
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
password xxxxxx
login
scheduler allocate 20000 1000
ntp server 89.188.26.129
end
04-23-2011 01:44 AM
To make sure, are you having problems with all inbound calls, or just to the CUE pilot? I don't see a voip dial-peer configured to connect calls to the service engine. I've included an example below that may help.
dial-peer voice 300 voip
description CUE Voicemail Pilot
destination-pattern *YOUR CUE PILOT*
session protocol sipv2
session target ipv4:10.1.211.62
dtmf-relay sip-notify
codec g711ulaw
no vad
If you're having problems with inbound calls in general, can you post a 'debug isdn q931' so we can verify the calls are hitting your gateway and the telco is sending the correct number of digits?
Steve H.
05-08-2011 03:13 AM
Thnx for ur reply...can we do the same by creating translation rules??? If so, then what will be the rule
