unable to call from pstn to h323 gateway (incoming calls)
techguy
Enthusiast
Enthusiast
I have configured CUE and i can call from internal and can listen the greeting message. but when i call from any other pstn number to main line (2811 cisco router acting as h323 Voice Gateway) calls have been dropped.
I call from ip phone to pstn (outgoing is ok) but problem is in incoming call.
Any clue???
CONFIGURATION is as below
boot-start-marker
boot-end-marker
card type e1 0 2
logging message-counter syslog
enable secret 5 $1$7SY2$Zwgh/Il4qYxg9DOFHpST.1
no aaa new-model
clock timezone GMT 4
network-clock-participate wic 2
network-clock-select 1 E1 0/2/0
dot11 syslog
ip source-route
ip cef
no ip domain lookup
isdn switch-type primary-net5
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
sip
  bind control source-interface Loopback101
  bind media source-interface Loopback101
  registrar server
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice class h323 1
  h225 timeout tcp establish 3
voice register global
mode cme
source-address 10.1.211.1 port 5060
max-dn 100
authenticate register
voice-card 0
dspfarm
dsp services dspfarm
application
global
  service alternate default
log config
  hidekeys
controller E1 0/2/0
framing NO-CRC4
pri-group timeslots 1-10,16
ip address 10.1.211.1 255.255.255.192
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.1.211.1
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Integrated-Service-Engine1/0
ip unnumbered Loopback101
service-module ip address 10.1.211.62 255.255.255.192
service-module ip default-gateway 10.1.211.1
no keepalive
router eigrp 1
network 172.16.40.0 0.0.0.3
network 172.16.250.24 0.0.0.3
network 192.168.84.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.16.40.1
ip route 10.1.211.62 255.255.255.255 Integrated-Service-Engine1/0
ip route 172.16.250.12 255.255.255.252 172.16.250.25
ip route 172.16.250.28 255.255.255.252 172.16.250.25
no ip http server
no ip http secure-server
control-plane
call fallback active
voice-port 0/2/0:15
bearer-cap Speech
no ccm-manager fax protocol cisco
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp fax t38 ecm
sccp local Loopback101
sccp ccm 10.50.2.3 identifier 1 version 7.0
sccp ccm 10.50.2.4 identifier 2 version 7.0
sccp
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 10 pots
tone ringback alert-no-PI
description International
destination-pattern 900.T
fax rate disable
port 0/2/0:15
prefix 00
dial-peer voice 11 pots
description Emergency
destination-pattern 9600....
fax rate disable
port 0/2/0:15
prefix 600
dial-peer voice 12 pots
destination-pattern 9800....
fax rate disable
port 0/2/0:15
prefix 800
dial-peer voice 13 pots
description Mobile
destination-pattern 905........
fax rate disable
port 0/2/0:15
prefix 05
dial-peer voice 14 pots
description National
destination-pattern 90[234678].......
fax rate disable
port 0/2/0:15
prefix 0
dial-peer voice 15 pots
description Local
destination-pattern 9.......
fax rate disable
port 0/2/0:15
dial-peer voice 16 pots
fax rate disable
port 0/2/0:15
dial-peer voice 100 voip
description To CallManager Pub
preference 1
destination-pattern [789]..
voice-class codec 1
voice-class h323 1
session target ipv4:10.50.2.3
dtmf-relay h245-alphanumeric
req-qos guaranteed-delay audio
acc-qos guaranteed-delay audio
fax-relay ecm disable
fax rate 14400
fax nsf 000000
fax protocol pass-through g711ulaw
no vad
dial-peer voice 200 voip
description To CallManager Sub
huntstop
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:10.50.2.4
fax rate 14400
fax nsf 000000
no vad
gateway
timer receive-rtp 1200
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
ip source-address 10.1.211.1 port 2000
max-ephones 42
max-dn 144
line con 0
speed 115200
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
password xxxxxx
login
scheduler allocate 20000 1000
ntp server 89.188.26.129
end
steve.hammes
Enthusiast
Enthusiast
To make sure, are you having problems with all inbound calls, or just to the CUE pilot?  I don't see a voip dial-peer configured to connect calls to the service engine.  I've included an example below that may help.
dial-peer voice 300 voip
description CUE Voicemail Pilot
destination-pattern *YOUR CUE PILOT*
session protocol sipv2
session target ipv4:10.1.211.62
dtmf-relay sip-notify
codec g711ulaw
no vad
If you're having problems with inbound calls in general, can you post a 'debug isdn q931' so we can verify the calls are hitting your gateway and the telco is sending the correct number of digits?
Steve H.
Thnx for ur reply...can we do the same by creating translation rules??? If so, then what will be the rule
Recognize Your Peers
