10-19-2016 01:48 AM
I am having the issue that I am unable to make an incoming call to one number only (main line). But I can call in to other numbers except the main line.Call out is no problem.
The call flow: External <--------->Tel <------->ISDN ------->Cisco router 2851 <-----(H323)------------> CUCM 9.1.2 <------------------> IP Phones
Someone can help me?
show isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 2
Total Allocated ISDN CCBs = 0
debug isdn q931
001942: Oct 19 14:03:24.790 SG: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x0061
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9839B
Exclusive, Channel 27
Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x4183, '8218XXXX'
Plan:ISDN, Type:Subscriber(local)
Called Party Number i = 0xC1, '6305XXXX'
001943: Oct 19 14:03:24.794 SG: ISDN Se0/0/0:15 Q931: Received SETUP callref = 0x8061 callID = 0x0097 switch = primary-net5 interface = User
001944: Oct 19 14:03:24.806 SG: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8 callref = 0x8061
001945: Oct 19 14:03:24.918 SG: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 94A3CAD394F811E68098001BD40A3348, SetupTime 14:03:24.808 SG Wed Oct 19 2016, PeerAddress 6305XXXX, PeerSubAddress , DisconnectCause 1B , DisconnectText destination out of order (27), ConnectTime 14:03:24.918 SG Wed Oct 19 2016, DisconnectTime 14:03:24.918 SG Wed Oct 19 2016, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
001946: Oct 19 14:03:24.922 SG: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:10/19/2016 14:03:24.802,cgn:8218XXXX,cdn:6305XXXX,frs:0,fid:612,fcid:94A3CAD394F811E68098001BD40A3348,legID:264,bguid:94A3CAD394F811E68098001BD40A3348
001947: Oct 19 14:03:25.038 SG: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 94A3CAD394F811E68098001BD40A3348, SetupTime 14:03:24.928 SG Wed Oct 19 2016, PeerAddress 6305XXXX, PeerSubAddress , DisconnectCause 1B , DisconnectText destination out of order (27), ConnectTime 14:03:25.038 SG Wed Oct 19 2016, DisconnectTime 14:03:25.038 SG Wed Oct 19 2016, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
001948: Oct 19 14:03:25.042 SG: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:10/19/2016 14:03:24.922,cgn:8218XXXX,cdn:6305XXXX,frs:0,fid:613,fcid:94A3CAD394F811E68098001BD40A3348,legID:265,bguid:94A3CAD394F811E68098001BD40A3348
001949: Oct 19 14:03:25.046 SG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26 disconnected from unknown , call lasted 0 seconds
001950: Oct 19 14:03:25.046 SG: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8 callref = 0x8061
Cause i = 0x809B - Destination out of order
001951: Oct 19 14:03:25.174 SG: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8 callref = 0x0061
001952: Oct 19 14:03:25.174 SG: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x8061
001953: Oct 19 14:03:25.178 SG: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 94A3CAD394F811E68098001BD40A3348, SetupTime 14:03:24.798 SG Wed Oct 19 2016, PeerAddress 8218XXXX, PeerSubAddress , DisconnectCause 1B , DisconnectText destination out of order (27), ConnectTime 14:03:25.178 SG Wed Oct 19 2016, DisconnectTime 14:03:25.178 SG Wed Oct 19 2016, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
001954: Oct 19 14:03:25.178 SG: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:10/19/2016 14:03:24.798,cgn:8218XXXX,cdn:6305XXXX,frs:0,fid:611,fcid:94A3CAD394F811E68098001BD40A3348,legID:263,bguid:94A3CAD394F811E68098001BD40A3348
10-20-2016 12:16 AM
when you make the inbound call to main number, do you see it hit any of the dial-peer on the router ?
10-20-2016 02:59 AM
Yes, i can see it.
Sending Complete
Standard = CCITT
10-20-2016 11:10 PM
Hii
I'm not very good with IDSN's but try using debug voice ccapi inout..It will tell you which dial-peer the call hits...If you can find which dial-peers the call is hitting it will help you check where the issue is...
Also if you study the ISDN debug carefully it should have a disconnect cause if the call is dropping.
>>>>>>Also when you dial the main number what you hear on the phone ? does it beep or goes dead or plays any message ? and is it configured/assigned to any phone ?
As you mentioned you have CUCM, try using the dialed number analyzer..If i'm not wrong it helps you trace the path for incoming call as well.
12-19-2016 05:52 AM
Is this resolved?
If not, it seems that the number is not assigned to anything.
Can you collect the following logs as well?
Debug voice ccapi inout
debug h225 asn1
