Unable to match incoming calls to a dialpeer
Ajlal Haider
I have a Cisco 2912 (CUBE) registered to voip.ms. All  the outbound calls work just fine. I am not able to make the incoming  calls work. When an incoming call is places the CUBE doesn't match any  incoming dial peer instead the outboud dial-peer is matched (please see  the debug below). The cube is sitting behind an ASA 5510, however, the  public IP assigned to CUBE's loopback is not being natted as it gives to  many problems when cube traffc is natted. I have also attached a  network diagram to this post. The following config is on the 2921  router. Also I have pasted the dialpeer and CCSIP debugs.
SHOW RUN
Current configuration : 8069 bytes
! Last configuration change at 13:32:55 UTC Mon Dec 16 2013 by ajlal
version 15.2
service password-encryption
hostname SEC-HO-VGATEWAY01
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
logging buffered 51200 warnings
no aaa new-model
ip cef
ip domain name yrns.local
ip name-server 10.13.11.2
ip name-server 192.168.60.4
no ipv6 cef
voice-card 0
dsp services dspfarm
voice service voip
ip address trusted list
  ipv4 184.75.215.114
ip address trusted call-block cause not-in-cug
gcid
clid substitute name
address-hiding
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface Loopback0
  bind media source-interface Loopback0
  session transport tcp
  e911
  transport switch udp tcp
  asserted-id ppi
  localhost dns:sec-ho-vgateway01.yrns.local
  midcall-signaling passthru
  no call service stop
voice class uri 1001 sip
host ipv4:184.75.215.114
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 ilbc
voice translation-rule 1
rule 1 /^123456\(....\)$/ /\1/
voice translation-profile INBOUND_TRANS
translate called 1
redundancy
interface Loopback0
ip address 64.187.178.132 255.255.255.224
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description TO_ASA
ip address 10.13.255.13 255.255.255.252
duplex full
speed 1000
interface GigabitEthernet0/1
description TO_LOCAL_LAN
ip address 10.13.14.1 255.255.255.0
ip helper-address 192.168.60.4
duplex full
speed 1000
router eigrp 13
network 10.10.10.10 0.0.0.0
network 10.13.10.2 0.0.0.0
network 10.13.14.0 0.0.0.255
network 10.13.255.12 0.0.0.3
network 64.187.178.132 0.0.0.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
mgcp profile default
sccp local Loopback0
sccp ccm 10.13.14.22 identifier 2 version 7.0
sccp ccm 10.13.14.21 identifier 1 version 7.0
sccp
sccp ccm group 1
bind interface Loopback0
associate ccm 2 priority 1
associate ccm 1 priority 2
associate profile 4 register SECHO-G729-MTP
associate profile 3 register SECHO-G711-MTP
associate profile 2 register SECHO-HW-CFB
associate profile 1 register SECHO-HW-XCode
dspfarm profile 1 transcode
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
maximum sessions 2
associate application SCCP
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729r8
maximum sessions 2
dspfarm profile 3 mtp
codec g711ulaw
maximum sessions software 100
dspfarm profile 4 mtp
codec g729r8
dial-peer voice 1001 voip
description SIP TRUNK TO CUCM-SUB01
preference 1
destination-pattern 5...
session protocol sipv2
session target ipv4:10.13.14.21
voice-class codec 1
dial-peer voice 1002 voip
preference 1
destination-pattern 1...$
voice-class codec 1
dial-peer voice 101 voip
preference 1
destination-pattern [2-9]..[2-9]......$
session target dns:toronto2.voip.ms
session transport udp
no voice-class sip block 180
no voice-class sip block 183
no voice-class sip block 181
voice-class sip bind control source-interface Loopback0
voice-class sip bind media source-interface Loopback0
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 103 voip
preference 1
destination-pattern 911$
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 102 voip
preference 1
destination-pattern 1[2-9]..[2-9]......$
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1 voip
incoming uri via 1001
dtmf-relay rtp-nte
codec transparent
no vad
dial-peer voice 501 voip
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer hunt 1
sip-ua
credentials username USERNAME password 7 PASSWORD realm toronto2.voip.ms
authentication username USERNAME password 7 PASSWORD realm toronto2.voip.ms
registrar 1 dns:toronto2.voip.ms expires 300 auth-realm toronto2.voip.ms
gatekeeper
shutdown
line con 0
exec-timeout 60 0
logging synchronous
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
exec-timeout 60 0
privilege level 15
logging synchronous
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
end
DEBUG VOICE DIALPEER ALL
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=2893211281, Called Number=2893211281, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=2893211281
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Dial String=2893211281, Expanded String=2893211281, Calling Number=2893211281T
   Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
   Result=Success(0); Outgoing Dial-peer=101 Is Matched
   Result=Success(0) after DP_MATCH_DEST
*Dec 16 14:44
SEC-HO-VGATEWAY01#:16.165: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=2893211281, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=101
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6473215943, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Match Rule=DP_MATCH_ANSWER; Calling Number=6473215943
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Is Incoming=TRUE, Number Expansion=FALSE
   Dial String=, Expanded String=, Calling Number=6473215943T
   Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
   Result=-1
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@6076
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=6473215943
SEC-HO-VGATEWAY01#Number=6473215943T
   Result=Success(0); Incoming Dial-peer=101 Is Matched
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=101
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
*Dec 16 14:44:16.165: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6704
*Dec 16 14:44:16.169: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Dec 16 14:44:16.169: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
*Dec 16 14:44:16.169: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
   Result=-1
*Dec 16 14:44:16.169: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@6076
*Dec 16 14:44:16.169: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
*Dec 16 14:44:16.169: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Dec 16 14:44:16.169: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6704
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6473215943, Called Number=2893211281, Voice-Interface=0x0,
SEC-HO-VGATEWAY01#EER_TYPE_VOICE,
   Match Rule=DP_MATCH_VIA_URI; URI=sip:184.75.215.114:5060
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/dpMatchPeertype:
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/dpMatchCore:
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/MatchNextPeer:
   Result=Success(0); Incoming Dial-peer=1 Is Matched
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/dpMatchPeertype:exit@6076
   Result=Success(0) after DP_MATCH_VIA_URI; Incoming Dial-peer=1
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/dpMatchSafModulePlugin:
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/dpAssociateIncomingPeerSPI:exit@6655
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=2893211281, Peer Info Type=DIALPEER_INFO_SPEECH
   dialstring=2893211281, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
*Dec 16 14:44:16.169: //-1/5F20307A81F3/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Dec 16 14:44:16.173: //-1/5F20307A81F3/DPM/dpMatchPeersCore:
*Dec 16 14:44:16.173: //-1/5F20307A81F3/DPM/dpMatchCore:
*Dec 16 14:44:16.173: //-1/5F20307A81F3/DPM/MatchNextPeer:
*Dec 16 14:44:16.173: //-1/5F20307A81F3/DPM/dpMatchSafModulePlugin:
*Dec 16 14:44:16.173: //-1/5F20307A81F3/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2893211281, Called Number=, Voice-Interface=0x0,
   Match Rule=DP_MATCH_ANSWER; Calling Number=2893211281
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
   Dial String=, Expanded String=, Calling Number=2893211281T
   Result=-1
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@6076
   Match Rule=DP_MATCH_ORIGINATE; Calling Number=2893211281
   Re
SEC-HO-VGATEWAY01#sult=Success(0); Incoming Dial-peer=101 Is Matched
*Dec 16 14:44:16.173: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@6704
   Result=-1
   Result=SUCCESS(0)
