Very Urgent!! Please advice
sting712
Dear support,
I wanna make a solution of Qos for voice over IP over frame-relay ..
I have the following :
* 2 routers 1601 with 8 MB Dram / 4 MB flash with IOS version 12.0 (7)T &
12.0 ( 8)
* 2 routers 805 with 8 MB Dram / 4 MB flash with IOS 12.2(3)
* A main site with 256 Kbps and 3 sites 64 kbps each with
( frame - relay lmi-type ansi , frame-relay IETF )
I want to Apply the following Qos configuration :
1-LLQ with priority
2-frame relay traffic-shaping
3-IP rtp header-compression
4-Output service policy in the map-class associated with Dlci
5-FRF.12 to fragment the packets ( 80 Bytes )
Can i apply the following commands with the current configuration or i must upgrade something( flash memory for new IOS or router model )
Please i need your help in this ...Thanks a lot
Waiting for your reply as soon as possible..
Best regards,
Sherif
mchin345
Level 6
Level 6
I guess, with the features you are looking for on a 1600 router, you should upgrade your flash memory to minimum 12MB. With the Software Advisor tool I could get a list all the Cisco IOS images which you could upload for the features you have mentioned. It is available at:
http://www.cisco.com/cgi-bin/Support/CompNav/CN1.pl?HMajorRelease=&HFeatSelected=449%7C485%7C730%7C17%7C205%7C681&HReleaseNumber=All&HReleaseId=-1&HPlatformFamilyName=1600&HPlatformFamilyId=12&HFeatureSetName=NS&HFeatureSetId=0&HRN_Given=1&HPF_Given=...
The IOS which you have currently on your 1600 router is not enough to have the traffic shaping, llq and other stuff. The minimum IOS version you would require is:
12.2(2)T which requires 4MB Dram and 12MB flash. For more details you can refer the link given above.
And as far as the 805 router is concerned, I do not think that frame relay traffic shaping is supported. The rest are supported from 12.1(5)T onwards.This requires 8 MB Dram and 8MB flash. The same can be verified on the Sofware Advisor.
