vg200 isdn bri problem
hmadinata
dear all,
I have [IPPhone] - [CCM] - (voip FastEthernet) - [VG200 as H323 GW] - (pots ISDN/BRI VIC) - [PSTN] configuration, and I make dial-peers inside VG200 like below:
dial-peer voice 3 pots
answer-address 0
direct-inward-dial
prefix 00
dial-peer voice 4 voip
destination-pattern 00
session target ipv4:[MyIPPhoneIPAddr]
dial-peer voice 5 voip
answer-address [MyIPPhoneDN]
dial-peer voice 6 pots
destination-pattern 22T
port 1/0/0
from the debug information (isdn q931, cch323 h225, voip ccapi inout), I can see that :
1) both legs (voip and pots) are matched when calling from IPPhone to PSTN, but outbound call from VG200 is failed (Cause i = 0x82E46C - Invalid information element contents).
2) only pots leg is matched when calling from PSTN to IPPhone (Cause i = 0x8081 - Unallocated/unassigned number), I think this because no more peer match to make outbound call (ssaCallSetupInd cid(3), st(SSA_CS_CALL_SETTING),oldst(0),ev(24)dpMatchPeersMoreArg result= -1)
- I dont understand th reason of 1) disconnect.
- 2) disconnect shouldnt be happened because it already match peer #3 (cc_api_call_setup_ind vdbPtr=0x811B809C,callInfo=called=,called_oct3=0x81,calling=0948260968,calling_oct3=0x0,calling_oct3a=0x83,calling_xlated=false,subscriber_type_str=RegularLine,fdest=1,peer_tag=3, prog_ind=0},callID=0x80E77590)), where prefix 00 then added to match peer #4 to do outbound call to IPPhone.
can anyone explain me? below is my necessary config infos:
no mgcp timer receive-rtcp
call rsvp-sync
isdn switch-type ntt
voice call send-alert
voice rtp send-recv
interface FastEthernet0/0
ip address [MyGWIPAddr] [MyGWNetmask]
no ip route-cache
no ip mroute-cache
duplex auto
speed auto
no cdp enable
h323-gateway voip interface
interface BRI1/0
no ip address
no ip route-cache
no ip mroute-cache
no logging event link-status
isdn incoming-voice voice
isdn send-alerting
voice-port 1/0/0
cptone JP
Not applicable
I wonder why the voice port has not been configured for the "dial peer 3". Could you check if this is causing the problem.
Check out the following document for more details.
H.323 Gateway Configuration
http://www.cisco.com/en/US/products/hw/gatecont/ps2249/products_configuration_guide_chapter09186a0080087d8a.html#xtocid164135
