1633
Beginner
voice-class sip not binding to correct interfaces?
                   Hello everyone, having a problem here that only happens on a 3900 router running a c3900-universalk9-mz.SPA.151-4.M4.bin IOS.  We have a 2900 router and tried to duplicate the problem but the bindings functioned as they should, only on the interface designated.  On to the problem, the 3900 router is set to a serial interface but it for some reason binds to a FastEthernet interface.
Here is what we have it set to:
sh run | sec 30002
dial-peer voice 30002 voip
description \\\\ Secondary Outgoing Domestic to AU AudioCodes \\\\
translation-profile outgoing ToAudioCodes
preference 1
destination-pattern 9[2-9]..[2-9]......
signaling forward unconditional
session protocol sipv2
session target ipv4:209.99.48.156
no voice-class sip g729 annexb-all
voice-class sip early-offer forced
voice-class sip profiles 2
voice-class sip bind control source-interface Serial0/1/0
voice-class sip bind media source-interface Serial0/1/0
dtmf-relay rtp-nte
fax-relay ecm disable
no fax-relay sg3-to-g3
fax rate 14400
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
no vad
However, it doesnt stay on the serial interface.
The routers process for applying the binding shows its’ ugly head in CCSIP Message debugs and a show dial-peer output.
Sent:
INVITE sip:+17032539080@209.99.48.156:5060 SIP/2.0
Via: SIP/2.0/UDP 10.101.97.241:5060;branch=z9hG4bKC1428
From: "8645465371" <sip:8645465371@10.101.97.241>;tag=23BA0920-16EC
To: <sip:+17032539080@209.99.48.156>
Date: Wed, 29 Aug 2012 20:54:53 GMT
Call-ID: 9DC3D192-F15211E1-8027F877-27180C5E@10.101.97.241
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 2646576098-4048687585-2149709943-0655887454
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1346273693
Contact: <sip:8645465371@10.101.97.241:5060>
Expires: 1200
Allow-Events: telephone-event
Max-Forwards: 69
Session-Expires:  1800
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 273
v=0
o=CiscoSystemsSIP-GW-UserAgent 9700 2242 IN IP4 10.101.97.241
s=SIP Call
c=IN IP4 10.101.97.241                                   ß SDP message sent to the SBC showing the bind to Fa0/1 IP, vs S0/1/0
t=0 0
m=audio 16522 RTP/AVP 18 101
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
FLBgrmIDIQVGR01#show dial-peer voice 30002
VoiceOverIpPeer30002
        peer type = voice, system default peer = FALSE, information type = voice,
        description = `\\\\ Secondary Outgoing Domestic to AU AudioCodes \\\\',
        tag = 30002, destination-pattern = `9[2-9]..[2-9]......',
        …. (removed over 50 lines ease of reading)
        voice class sip bind control = enabled, 10.101.97.241,             ß Show dial-peer output showing the bind to Fa0/1 IP
        voice class sip bind media = enabled, 10.101.97.241,
Why is it binding to a Fa0/1 interface when we specifically told it to bind to a serial interface?  Is this a version issue?  Is there something I am missing?
Everyone's tags (4)
4 REPLIES 4
Beginner
duplicate post, disregard! sorry!
Brandon
Did you solve this issue?
I meet the exact same problem on a 3925 running verison 15.1(3)T4
Highlighted
Beginner
We did resolve the issue and it was a multi-part resolution.
First, apparently the IOS had a known bug causing this problem so we upgraded to 15.2
Second, whatever you have set in group 0 is what it WILL bind to regardless of what you have set elsewere which is really weird...
Honestly, I don't see the point of having other groups if it always binds to group 0.
FLBgrmIDIQVGR01#show standby
GigabitEthernet0/1 - Group 2 (version 2)
  State is Active
    11 state changes, last state change 2d21h
  Virtual IP address is 10.101.97.241
  Active virtual MAC address is 0000.0c9f.f002
    Local virtual MAC address is 0000.0c9f.f002 (v2 default)
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 2.160 secs
  Preemption enabled, delay min 30 secs
  Active router is local
  Standby router is 10.101.97.243, priority 100 (expires in 10.288 sec)
  Priority 110 (configured 110)
    Track object 2 (unknown)
  Group name is "hsrp-Gi0/1-2" (default)
GigabitEthernet0/2 - Group 0 (version 2)
  State is Active
    1 state change, last state change 21w0d
  Virtual IP address is 202.161.136.113
  Active virtual MAC address is 0000.0c9f.f000
    Local virtual MAC address is 0000.0c9f.f000 (v2 default)
    Next hello sent in 0.896 secs
  Preemption enabled
  Standby router is 202.161.136.116, priority 100 (expires in 9.616 sec)
  Group name is "SB" (cfgd)
So yeah...that was our solution and I hope it works for you.  If it doesn't I'm not sure what else to tell you.
Thanks a lot Brandon
I'm going to upgrade to 15.2 or 15.3 and see what will happen
P.
Content for Community-Ad
August's Community Spotlight Awards
