10-20-2008 02:15 AM
pstn pri is connected on my 3845 router (VWIC-2MFT-T1). E1 is up and ISDN layer 2 is also up. When I am dialing the calls I am getting some error.
Expecting some ones help to resolve the issue.
DEBUG ISDN Q931 OUT PUT
VoiceGW#
Oct 20 12:03:57.484 INDIA: ISDN Se0/1/0:23 Q931: RX <- SERVICE pd = 3 callref =
0x00
Change Status i = 0xC0 - in-service
Channel ID i = 0xAC
Oct 20 12:04:02.484 INDIA: ISDN Se0/1/0:23 Q931: RX <- SERVICE pd = 3 callref =
0x00
Channel ID i = 0xAC
Oct 20 12:04:07.481 INDIA: ISDN Se0/1/0:23 Q931: RX <- SERVICE pd = 3 callref =
0x00
Channel ID i = 0xAC
Oct 20 12:04:12.481 INDIA: ISDN Se0/1/0:23 Q931: RX <- SERVICE pd = 3 callref =
0x00
Channel ID i = 0xAC
Oct 20 12:04:17.057 INDIA: ISDN Se0/1/0:23 Q931: pak_private_number: Invalid typ
e/plan 0x0 0x0 may be overriden; sw-type 3
Oct 20 12:04:17.057 INDIA: ISDN Se0/1/0:23 Q931: Applying typeplan for sw-type 0
x3 is 0x2 0x1, Called num 017325908100
Oct 20 12:04:17.057 INDIA: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8 callref = 0
x0186
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x2183, '6821'
Plan:ISDN, Type:National
Called Party Number i = 0xA1, 'NUMBERDELETED'
Oct 20 12:04:17.485 INDIA: ISDN Se0/1/0:23 Q931: RX <- SERVICE pd = 3 callref =
0x00
Channel ID i = 0xAC
Oct 20 12:04:21.057 INDIA: ISDN Se0/1/0:23 Q931: TX -> SETUP pd = 8 callref = 0
x0186
10-21-2008 02:03 PM
All,
I have resolved this issue and now i am in the next level issue.
Now I can call any number from my end phone but I am not getting ringback tone. If the called party picked up the call, not able to hear calling and called party speaches. Both the way the voice is not working. Is there any specific commands to resolve this issue.
10-23-2008 05:15 AM
Guys,
The issue got resolved.Thanks to everyone.
10-25-2008 12:50 AM
I have the same issue as your last post. Can you tell me how did you resolved
THX
10-27-2008 08:26 PM
Hi. Gopi. How did u solve the problem. when ever solve the problem on your own, pls post it so that others will benefit.
regards
Gem
12-23-2008 11:48 PM
Not that i need this, but i think Gopi should respond to those who needs answers from him.
01-12-2009 12:39 AM
All,
Sorry for dely response.
When I commisioned the pri I have started with trunk group configuration and it was not working. Then I changed my config to nfas and it started working.
