11-28-2012 02:27 AM
Cisco 3700 with 124 serial interface
4 channelized E1/pri port .
how many calls this router is able to manage at the same time?
I mean dialplan is implemented to manage TDM to VOIP and also IP to IP call routing.
In case of all 4 PRI channel are is use ( all channels busy) for call from TDM to IP with g729 codec, can the router manage additional call in IP (sip) to IP (sip) routing scenario?
11-30-2012 01:32 PM
4 x 30 = 120 calls.
However the 3700 is an old model, you should upgrade ASAP.
01-23-2013 08:16 AM
Does it mean that the router can mange 120 call in Total that could be a Mix between calls TDM to IP (or viceversa ) and also Sip to Sip ?
thx
01-24-2013 12:17 AM
Hi - 120 PSTN calls through 4E1 PRI lines. The number of IP Calls depend on your WAN bandwidth. And if QoS is implented how much bandwidth is allocated for voice traffic. PSTN calls will be routed via E1 lines unless you have a SIP Trunk as well to ITSP. IP Calls will be routed over WAN.
Roughly, g729 uses 24k and g711 uses 80k. You can divide it by your allocated WAN BW and get no of calls. For example: 240k bw will allow roughly close to 10 g729 calls.
Please let us know if you have further questions. If this resolves your query please mark the thread as answered and rate all helpful posts.
Terry
