Highlighted
voip inbound call
Hi, i just received my UC540 and try to configure the sip trunking.
SIP outgoing calls are ok, but not incoming ...
when i active the debugging, the logs shows me :
003312: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=3397999447, Called Number=33974999447, Peer Info Type=DIALPEER_INFO_SPEECH
003313: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=33974999447
003314: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Result=Success(0) after DP_MATCH_DEST
003315: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=33974760447, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
003316: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=20008
     2: Dial-peer Tag=20015
UC_540_astelia#
UC_540_astelia#
003317: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=33684752481, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
003318: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
003319: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
003320: //-1/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
   CALL_ERROR_INFORMATIONAL; Call Id Is Invalid=-1
003321: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
so two dial peers seems to match
I created with CCA the direct dialing :
but it doesn't work.
Where is the problem ?
Everyone's tags (4)
Content for Community-Ad
August's Community Spotlight Awards
