VOIP inconsistency
c.ong
I'm encountering some VOIP problems. I have
problems getting calls to a remote site. I reloaded the router and voip is
working fine again.
However after the router was reloaded, i busyout forced on 3 voip ports,
leaving only one port empty, the ratio to get connected on that one port is
50%. Is this a normal ratio?
On certain ports, the ratio is 25%.
I also got this error msg while i was on the telnet terminal
Router#sh voice port su
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
1/0/0 -- e&m-imd up dorm seized idle y
1/0/1 -- e&m-imd up dorm idle idle y
1/1/0 -- e&m-imd up up idle seized y
1/1/1 -- e&m-imd up up idle seized y
Router#
00:15:50: vtsp_process_event: pev->cdb = NULL, ID 81
00:15:50: vtsp_process_event: pev->cdb = NULL, ID 82
00:15:50: vtsp_process_event: pev->cdb = NULL, ID 86
router#sh debug
00:16:03: %ALIGN-3-SPURIOUS: Spurious memory access made at 0x80C8AE30
reading 0
x4C
00:16:44: vtsp_process_event: pev->cdb = NULL, ID 81
00:16:44: vtsp_process_event: pev->cdb = NULL, ID 82
00:16:44: vtsp_process_event: pev->cdb = NULL, ID 86
00:17:01: %VTSP-3-DSP_TIMEOUT: DSP timeout on event 6: DSP ID=0x1: DSP
error stats
Thanks.
Delon
p.krane
Level 3
Level 3
The VTSP-3-DSP_TIMEOUT message is related to load and is most likely due to short term cpu load. These messages are not seen in the latest 12.2 images.
The ALIGN-3-SPURIOUS message indicates the IOS attempted to access memory in a restricted location. Here is a link on troubleshooting spurious and aligment errors:
http://www.cisco.com/warp/public/63/spuraccess.html
