07-18-2007 04:33 AM
The Cisco High-Density Analog and Digital Extension Module for Voice and Fax (EVM-HD) contains FXS and FXO ports ?
Or I need to buy additional modules with these ports ?
07-18-2007 07:33 AM
The EVM-HD itself does not include any FXS/FXO ports. EVM-HD-8FXSDID includes the EVM-HD and an 8-port FXS/DID extension module. You can also purchase other extension modules with different port configurations. See Table 1 in the following link.
http://www.cisco.com/en/US/products/ps5855/products_data_sheet0900aecd8016c1c6.html
Hope this helps. If so, please rate the post.
Brandon
07-19-2007 12:34 AM
Many thanks. But this module can works alone, or I need to buy another DSP module? Router will be connected with PABX central (FXO/FXS)to internal or external ports PABX. Can I use Cisco 2851?
07-19-2007 04:36 AM
It depends on the DSPs you currently have and how they are being used. If all current DSPs are in use, you will need another DSP module. Yes, you can use this module with the 2851. Refer to the link that I previously posted.
Hope this helps.
Brandon
07-19-2007 04:39 AM
be aware tha connecting to PBX via FXS / FXO is not the best way to do integration as you will encounter severe limitations. Please investigate if you can have ISDN BRI, PRI or at very least, analog E&M on the PBX.
07-19-2007 04:41 AM
be aware that connecting to PBX via FXS / FXO is not the best way to do integration as you will encounter severe limitations. Please investigate if you can have ISDN BRI, PRI or at very least, analog E&M on the PBX.
