VOIP QoS - Is tagging enough?
pepechingon
I have a question about setting up QoS for VOIP on a campus. Is it wrong to assume that as long as the packet is tagged with EF, and trust is enabled on all trunk ports that the switch will prioritize the VOIP traffic? Or do is I still need to configure the queues?
All traffic is being tagged by the devices, and running over a large L2 network.
I appreciate the help.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Guaranteed wrong - no, but very likely it's incorrect.
Depends on the device's default and what you want to accomplish.
On many most Catalyst switches, QoS is disabled by default.  Enabling it will often default to all ToS markings being erased, default different CoS/ToS markings mapped to different queues, default proportional resource allocations, default no PQ for EF traffic.
If your switches support it, AutoQoS might be sufficient, alone, to prioritize your EF tagged traffic.
