01-04-2004 11:25 AM
I have a SOHO currently using cable modem connected to the outside interface of a PIX 501. The inside interface of the PIX connects to a hub with 8 ports.I have 2 PC's and a LinkSys AP plugged into the hub. I have been looking at using Vonage VoIP. My questions are:
1) Is it possible?
2) Do I need to use a special fixup protocol or config?
3) Has anyone used Vonage VoIP and how is it working?
Paul Lane
01-05-2004 03:14 PM
Paul,
I have been using Vonage succesfully with a very similar configuration. You don't neet any fixups or special configurations to make this work.
My only suggestion is to connect your ATA to a switch port behind the PIX, as opposed to the hub.
Have fun!
Fernando Macias
01-05-2004 06:27 PM
Thanks you!
01-16-2004 05:07 AM
Hi Luis,
I plugged the Motorola ATA into one of the 4 available ports in back of the PIX 501, and I don't receive any dial tone at all. Has this ever happend to you? How did you set up your ATA?
Paul Lane
