504G - lights on, cannot provision
foxlumber
Beginner
Beginner
   Hi, I have a Cisco SPA504G that needs to be re-provisioned.  I see 3 lights on (see attachment):
Red Microphone Mute button
Green Headset button
Green Hands Free button
The display is dark, none of the other buttons work, I cannot get to the "Network" display.  The phone is on POE and I have unplugged and plugged in the switch connection, still no change.  How do I fix this?  Is there another way to factory reset the phone?  Thank you.
John
jenernetwork
Beginner
Beginner
John,
Please disconnect the attendant console and try again.
If that doesn't work out you can try using a power supply instead of POE maybe the switch can't deliver enough power to the phone
regards
Erik Dekkers
Jener Network Solutions
