7941 7975 not registering
aqeelimran
Beginner
Beginner
I was using cisco unified configuration on uc 500 and deleted extention while phone was plugedin
Now the phone does not connect and says registration failed
What should i do i am in big problem it was my boss extention
I did same misstake with 7975 also
Kindly help
Its urgent
ciscojoe837
Beginner
Beginner
If you didn't save the config just reload and the original startup-config will load.  Be sure not to save if asked.
I have saved the new config what now?
