9951 - 2nd line
davidfield
Level 3
Level 3
Hello All,
Commissioning a new system and my first install with the SIP 9951's and UC520.  With the help of some forum members we've managed to overcome the major issues I've experienced but its the small detail where I'm coming unstuck.
Issues I could do with some advice on;
- on the 9951 right hand side I have a button set for the FXO line 1 CO.  Can anyone advise how I get FXO line 2 to display so the users can select whichever line they want?
- Directory button on the 9951 syas no contacts.  Not sure how to get this linked to the system extensions
Any help greatly appreciated.
David
Hello David,
About the second question please add under voice register global:
url directory  http://ip address of the CME/localdirectory
HTH,
Alex
*Please rate helpful posts
Hello David,
HTH,
Alex
Thansk Alex that solved that one.  I did indeed change the default IP of the system which affected the directory on the SCCP phones also.
David
Thank you for the feedback and the rating! I am glad that the issue has been resolved.
As for the first question I do not fully understand what you need exactly - if you need to add another line like the first one or something else.
How exactly you have added the CO line?
Best regards,
Alex
