adding remote ip phone
rchakchouk
hello,
I want to add a remote cisco ip phone which is not connected to a pbx and related to a router to another system UC520 which is connecetd to 3 ip phones and making a call between them over the voip. is it possible? and if yes how can i configure that?
paolo bevilacqua
Yes, you will need a VPN setup. This kind of thigns is better to be done by a reputable consultant or UC certified cisco partner.
can you help me with a documentation or an overview about the neccessary steps because i should work this by myself and this is my first time that i work with the UC500. other thing i want to konw if is it neccessary to have a router connected to the UC500 or not? thanks
Again: it is not as easy as you may think, and it is not a task for the end user.
There is many professionals here that have spent time and money to get the necessary certifications and/or equivalent and better experience. Trying to reduce and replace these efforts to a web discussion thread would be very inappropriate, beside not effective.
So if you want to try by yourself you will have to start where everybody else has started before: read product documenantion and searching.
