Australian Settings for SPA9000 & SPA400
chris.bowra
Are there recommended settings for the FXO ports on the SPA400; line impedances, transmit & receive gain etc.?
I need to interface to a legacy PABX and would like to do so using the SPA9000's FXS ports. The PABX requires line supervision to operate properly in the desired manner and gives me ROI or ROA options to do so. Is this possible, and if so which settings do I need to adjust to accomplish it?
Cheers,
Chris
Patrick Born
Hi Chris,
The SPA400 Localization Configuration document may be of use to you:
https://www.myciscocommunity.com/docs/DOC-7414
In addition, the SPA9000 Admin Guide describes the FXS port configuration:
https://www.myciscocommunity.com/docs/DOC-1750
Patrick
