BACD vs Contact Center
jaydien1358
Level 3
Level 3
I understand that the UC500 series comes with BACD capabilities.
But am I correct in assuming that Cisco Contact Center Express can be integrated in the UC500 as well?
If so, what extra hardware/software/licenses are needed?
When features do you gain from contact center?
Lastly, is there a matrix published that shows the differences?
Thanks.
-Brian
Steven DiStefano
Basic ACD comes with UC500, very basically described:
https://supportforums.cisco.com/docs/DOC-9731
IPCCX has been interoperated with UC500 and was discussed here, which includes compatibility matrix:
https://supportforums.cisco.com/message/3089839#3089839
http://www.cisco.com/en/US/partner/products/sw/custcosw/ps1846/products_device_support_tables_list.html
There is a max of 12 agents supported for this integration.
CCX can only be sold by Express UC specialized partners as I recall.
Brandon Buffin
Brian,
     Yes UCCX is supported with the UC500 with some limitations. See the link below.
Contact Center Options on UC5200 & CUCME
https://supportforums.cisco.com/docs/DOC-9759/
Here is a link to the UCCX 8.0 datasheet which gives a list of features. Keep in mind that some of these are not available when integrated with UC500.
UCCX 8.0
http://www.cisco.com/en/US/prod/collateral/voicesw/custcosw/ps5693/ps1846/data_sheet_c78-588933.html
As far as additional requirements, you will need a server to run UCCX, UCCX server software and licenses for the number of agents that you need.
Hope this helps.
Brandon
Steven DiStefano
thanks.
