Backlight Brightness
tomlim526
We recently installed the last of our phones and I noticed that the backlighting for it is a lot brighter than ALL the other phones.  I think the other phones used to be this bright at the beginning too.
I also noticed the setting on all the other phones were set to backlight always on.  Do you think this may have caused them to become so dim??  I have left the latest one on 30s backlight timer.  I also tried setting one of the original phones to 30s, and it hasn't fixed it.
Any ideas on how to fix this??  Is there a backlight brightness setting that is hiding from me??
See attached photo for comparison.
5 Replies 5
nseto
Level 6
Level 6
Yes, this is a known issue whereby the light eventually dims after being set to 'always on'.  There isn't a fix for this.
Newer versions of the phone have a reduction in backlight output to begin with, so it won't dim so dramatically like what you are seeing.
ncixbrian
How did you manage to write "Koziak" on the phone's screen?
I didn't tried it by self as I have no test phone here just now, but I assume:
Select Logo=Text Logo
Text Logo=Koziak
Which section is the Select logo option?
It's on [ Phone ] tab.
But I'm sure you can find it by self even with no advice ...
