Basic setup for SPA3102
daniel
Beginner
Beginner
Hi, I've got this information from my ISP for using with VOIP but I am not really sure where to configure it on the SPA3102:
SIP-username
SIP-password
SIP-Server
Voicemail
Username
Password
Thanks in advance!
/Daniel
dhames
Beginner
Beginner
If you have your PC plugged into the yellow Ethernet port on the SPA3102, then you will need to access the device's interface by going to: http://192.168.0.1/admin/voice/advanced/
Once the GUI loads:
-Click on the "Line 1" tab.
-Scroll down until you see "Proxy and Registration" and "Subscriber Information"
That should do it.
dhames
Beginner
Beginner
Once the GUI loads:
That should do it.
Thanks, I thought that was the place to change the settings but it feels better to getting it confirmed :).
Recognize Your Peers
