Batch Import of System Speed Dial list
sreed
Is there a way to bulk import a System Speed Dial list?
I tried editing the speeddial.xml and 'uploading' it but that doesn't work.
Steven DiStefano
When you configure it, it does push a speeddial.xml to flash.
Looks like this......
Directory of flash:/
    1  -rw-         660  Sep 10 2009 09:28:46 -05:00  vlan.dat
    2  -rw-    30088700  Sep 10 2009 09:21:30 -05:00  uc500-advipservicesk9-mz.124-24.SB
    3  drw-           0  Sep 16 2009 13:06:18 -05:00  phones
  101  drw-           0  Sep 10 2009 09:28:00 -05:00  Desktops
  120  drw-           0  Sep 10 2009 09:28:02 -05:00  autoattendant
  124  drw-           0  Sep 10 2009 09:28:12 -05:00  bacdprompts
  135  drw-           0  Sep 10 2009 09:28:14 -05:00  cca
  139  drw-           0  Sep 10 2009 09:28:24 -05:00  gui
  161  drw-           0  Sep 10 2009 09:28:32 -05:00  media
  164  drw-           0  Sep 10 2009 09:28:44 -05:00  ringtones
  198  drw-           0  Sep 10 2009 09:28:46 -05:00  sn
  201  -rw-       24440  Sep 10 2009 09:52:28 -05:00  UC540W-FXO-K9-factory-7.1.3.cfg
  202  -rw-         198  Oct 28 2009 16:38:40 -05:00  speeddial.xml
254021632 bytes total (123637760 bytes free)
UC540#more speeddial.xml
Local Speed DialsSelect an entrysteve919193921234
So I woould thnk you could TFTP it off manually, replace it and put it back, then have CCA read it?
I wonder if the editor you are using adds unneeded charachters?
CCA Help (apologize for fonts)
System Speed Dials
To configure System Speed Dials, choose Configure > Telephony > Voice Features > System Speed Dial from the feature bar.
From the System Speed Dial window, you can set local speed dial numbers.
Overview
A list of frequently called numbers can be created for all phones. A phone user can quickly dial a number from a list by using a speed-dial number. You can add, edit, or delete speed-dial entries. The list entries can be moved up or down the list and appear on the telephone display in the order in which they are listed. A maximum of 32 frequently called numbers can be defined in the list.
Procedures
To enable a local speed-dial menu for all IP phones, perform the following steps:
  • Click Add.
  • In the Name field, enter the name of the speed dial.
  • In the Phone Number field, enter the number for the speed dial.
  • To reorder a local speed-dial number in the list, select the entry, and click the up arrow or the down arrow. The numbers are listed in the order in which they are displayed on the phone.
  • To remove a local speed-dial number from the menu, select the entry in the menu, and click Delete in the Local Speed Dials box.
If the list has reached the maximum number of entries allowed, the Add button is disabled.
https://fsx.cisco.com/authc/forms/CDClogin.fcc?TYPE=33554433&REALMOID=06-852dfbac-39dd-102e-a636-83adda230000&GUID=NO&SMAUTHREASON=0&METHOD=GET&SMAGENTNAME=-SM-9bj7m4ek5iE1hm7oqu l8hb10E4DRdiKy3QJvZn1bPIOAqfNSaAdlygv5ODkF0s/&TARGET=-SM-HTTPS://fsx.ci...
