I have a UC-560 and 2 POE switches that I have had for almost 3 years now. Recently some of the SPA-504G phones are able to make calls, but when the user is ready to hang up the system does not disconnect that call. Any suggestions?
Hey guys, I currently have SPA514G which has 4 lines connected to a PBX. I plan to have max 6 phones. But I need to have more lines, planning to go with SPA508 to have 8 lines, but then I will lose the Gigabit option. I don't connect the phone to any...
Hi, I use a UC540 at my house for both the office(s) + house lines.My incoming dial plans do call blasting on different extention (depending on the number reach) after 60 sec if no one awnser it goes onto the Auto Attending (ext: 398, 397 or 396) ...
We are trying to downgrade the software on two new SPA525G2 phones that were purchased by a customer to match the rest of the phones in their network. The phones came with software version 7.5.5a and the rest of the phones in the network are running ...
Hello, I've been searching everywhere for a solution to the laptop/SPA504G PC Port problem which my customer is experiencing; this involves the cable not registering as being connected in the Network and Sharing Centre, here are two links I have foun...
HiWe have moved all our analog devices off our stable but ancient pbx to unreiable cisco ata's. Most alarm panels have been working okay on 1.2.1 (004) Jul 27 2012 firmware however we also have some Cardax diallers which show "All transfer attempts f...
Hello, i have problem to connect SPA112 through internet to SPA9000. The SPA9000 is on public fixed IP address. On PBX status it shows that SPA112 is connected(both ports) but i am not able to make or recive calls.Any idea what to try ?Settings on S...
Any body can help me to configure PSTN line with SPA112 for calling through 3cx IP PBX. How can i call through this PSTN number. My scenario is like this. ---> PSTN Line is connected SPA112 in port 1 instead----> SPA112 Connected to 3cx through LAN ...
Hi, I currently have incrediblepbx installed and did some tests with softwares, it is all good. Today I purchased 2 SPA514G phones, this is my first time using an IP phones. I am a total newbie. So I went to the phone ip and put my ID (101, which is ...
I can't seem to create a new discussion thread for this below: no idea why!! I tried twice.. (now it works..) I have 4 questions regarding Park Softkeys: PSK 1: fnc=sd;ext=70@192.168.1.111;vid=1;nme=Park1) Can I replace 192.168.1.111 by writing exact...
We recently installed the last of our phones and I noticed that the backlighting for it is a lot brighter than ALL the other phones. I think the other phones used to be this bright at the beginning too.I also noticed the setting on all the other pho...
Hi All,I'm hoping somebody can help me here. I have an SPA112 telephone adapter that gives me problems with the phone not going off hook to give me a dialtone.I upgraded the firmware to 1.3.5p recently, thinking this might fix the issue. It didn't,...
Hi – I put the password in for the voip (provided by ISP) but then got to this screen. Now I cant even login into the config of the phone. I have added the screen dumps below as attachments. I am not sure where I am meant to enter the settings:Passw...
Hi there,I have several SPA3102s in my enviroment that I am using to connect legacy PSTN lines to the VoIP network. Calls come in on the PSTN lines and are routed to our Asterisk server by the gateways. The Asterisk server connects the calls to the c...
Hi, I am having trouble with the paging feature. The phone freezes after hanging up a page. I noticed that this bug : CSCur44052 was fixed on 25th of January. Is there a way to know the release date of the fix and/or another way to have acces to the ...
