Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
Using an ATA 191 for analog-SIP conversion, we have a fax on line 1 and an analog phone on line 2. We experience following problem on line 2 with the analog phone: once the user finishes dialing (a 2 to 10-digits number), it takes 4 to 5 seconds for ...
info69 by Level 1
  • 4394 Views
  • 4 replies
Hello ,  i have upgraded the migrated the firmware of Cisco 8845 IP phone from enterprise firmware to MPP firmware.  Firmware migration went well and all seems good.. but when i tried to register the IP phone over SIP TLS to Asterisk PBX , it is alwa...
Hello, i have a IP Phone 7970 which won’t even attempt to pull the Firmware from the TFTP Server after a Hard Reset (3491672850*#).I am using TFTPD32 by Phillipe Jounin as DHCP and TFTP Server.Under the „Log“ tab I can see that it sends a DHCP Reques...
Hello Community! I have a simple question, which I cannot solve. Maybe you have a simple solution.Is it possible to deactivate an unallocated DN automatically? Or vice versa.Like, i'm going to prepare a new CUCM(11.5). The Clients should get the same...
matiusch by Level 1
  • 922 Views
  • 2 replies
Hi all,Does anyone know a way to setup a custom button to forward the current call you are on to a predetermined phone number? For example, a caller calls an extension, the Jabber user picks up the call and presses a button that transfers the call to...
Hi there.  I've got a couple 525G2s - and trying to pair different headsets via bluetooth.  After trying to pair, and not having my headsets detected, the handset then fails to work - no audio at all.  Even after a factory reset.
