HI,We have recently purchased BE6K- UCSC-C220 server from cisco partner. Now i want to verify support documents with Cisco. please explain how to check service & support years in the cisco web site.
may any member help me in putting in service the device? It is connected properly to my Iphone 8 but I can't speak and receice any callthanks a lotregards Tanino
I'm a hobbyist. I use my Cisco 525G2 with a small private Asterisk server.I'm trying to configure a Plantronics CS-540 with APC-45 cable to work with my phone.I have enabled Electronic HookSwitch in the settings on the phone.I can't get the headset t...
Hi there. I've got a couple 525G2s - and trying to pair different headsets via bluetooth. After trying to pair, and not having my headsets detected, the handset then fails to work - no audio at all. Even after a factory reset.
I was gifted a UC320W-FXO and 8SPA508G Phones, when I tried to connect to the UC320w its asking for adobe flash. Since adobe flash doesn't exist anymore, what can I do to access it to program it for our use?
Hi all! Hoping someone can help me here, Cisco is not my forte, mainly a Fortinet guy, however, a client is having an issue with their ASA that just started happening a few days ago, it is rebooting itself multiple times throughout the day (5+). I d...
Will my Cisco 7940 VOiP Phone work with my Cisco WS-C3560-48PS-S Catalyst 3560 Series PoE-48 Switch? Will Vonage work as a VOiP service provider or should I use something different? Any other things I should know or need to make it all work?Thank yo...
alguien que ayude al tema
I upgraded the firmware on my SPA962 to version 6.1.5a from version 6.1.3 and I'm now met with a phone telling me it's in SOS Recovery Mode.How do I get my phone back to a usable state?
I am trying to reset the UC540, because somehow I am not able to connect it using CCA, it always show connection Failed.and when I try to reset to factory default.This is what it showed.R1#service in0/0 sessionIP address needs to be configured on int...
I am looking for support with setting up SIP trunks from VoIP Innovations on this box. Small site setup if anyone still can help in NY on site or remote. Can I use included standard template to create SIP trunk which is not proxy type? Or it has to...
The ATA191 Provisioning Guide (p.149) defines <Allowed_Remote_IP_Address> as:Description—Specifies a remote IPv4 address that is allowed access to the web-based configuration utility, when Remote Management is enabledUser Interface—Administration > M...
Hello, I hope everyone is doing well. Just a quick question, does anyone know how to set line one to ring "silently" (without any sound) during set hours only? For example;During the hours from 0700 - 1700 ring with the soundDuring the hours from 170...
I have a 2921 running IOS 15.2(4)M6a and I have the problem descibed in bug CSCtl79911. External SCCP calls coming into the router from a remote 2821 through an IPSEC tunnel will connect to the called phone and I can carry on a coversation if I answ...
Hi guys, this is a really odd one that's not cabling-related. I wonder if anyone's seen this before or has any thoughts.I have set of SPA504G's that I'm trying to install on a LAN using PoE. The network seems fine, DHCP works fine for other devices...
